Question about Lenovo 3000 N200 Notebook
My lenovo 3000 n 200 will not start :/ the only thing i can see is a lamp showing " Y " . when i put the charger to the computer the lamp who showing that the computer charging is not lightning. when i press the start button, nothing respons..
  • 35 Answers
First tip is disconnect the battery and Adapter, hold down the power button for 30 sec. and the insert your battery and adapter and try starting. Let me know is this works or I can suggest something else.
Posted on Feb 06, 2010
Tip
DISASSEMBLING AND CHARGER CHECKING
LENOVO S5000-F - S5000-H
Checking the Computer AC Charger
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger.
To check the computer AC Charger, do the following:
1. Disconnect the micro-USB cable from the tablet.
2. Measure the output voltage across the connector marked B of the micro-USB cable. Refer to the following figure:
For more pictures and description check the link bellow. On search tab type Lenovo
www.electro-medical.blogspot.com/
google.com/+AjinGopakumar
on Mar 07, 2015 | Lenovo S5000 7" Android 1GB 16GB
Tip
DISSEMBLING AND CHARGER TESTING
LENOVO YOGATABLET 10 HD+
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger. To check the computer AC Charger, do the following:
For more pictures and description check the bellow link. On the search tap type lenovo.
on Mar 07, 2015 | Lenovo Yoga Tablet 10 HD 59411049 - Silver...
Lenovo A2107A doesnot start up, it is closed and doesnt accept charger !!!!
Check your charger. If you don't have an electronic tester, you should ask for service. Also might diagnose battery issue
Sep 17, 2013 | Lenovo IdeaTab A2107 7" 8GB Tablet
Lenovo a65 failed to boot or failed to turn ON
juast full out your battery and sd card sim in 1 to 2 seconds and theback it again and press power on and plug ur charger in usb port show it if its is running ur batttery icon located in the upper right side thats all try it now
Dec 11, 2012 | Lenovo A65 Smartphone
My lenovo netbook no displayed in the monotor screen. i see power when i turn it on. please help me to fix
Hi and welcome to fixya!
First thing you do for this is shut down the machine by just pressing and holding the power button for about 5 seconds.
Then unplugged the charger and take out the battery.
Next is press and hold the power button again for 10 seconds, without the charger and battery this time.
Put the battery back in and the charger and turn on the machine normally. This should solve the issue 95% of the time. If it does not, time to contact the warranty support for Lenovo.
Hope this helps!
Takasashi
Jul 15, 2011 | Lenovo IdeaPad S10-2 29577VU PC Notebook
My laptop has stopped charging altogether and won't turn on anymore. I don't know if it's an issue with the charger or the battery. What can I do to try to fix it?
I've seen many problems like this as a computer technician and here's what you can.
Find a replacement charger for your laptop online or a local computer shop. Most times, it's the charger. Laptops chargers usually only last 1-2 years before they start to show signs of failing.
If a new charger doesn't solve it, the problem could be internal, either the power jack inside the laptop or the motherboard.
Have a computer technician check out the laptop if the problem persists.
Also, check the Lenovo website if there has been any recalls on your specific laptop.
Hope this helped.
Apr 18, 2011 | Lenovo IdeaPad Y510 Notebook
I have an Lenovo Idea Pad S10-2, the laptop knows the battery which shows to be 100% full, but if i remove AC Power, there is no switch to battery as well if i try to start from battery
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard. Take out the battery and unplug the power adapter from the computer. Press and hold the power button for 10 secs. Put everything back in then tunr on the computer and observe the issue. If same thing will happen then the problem is somewhere in the motherboard connecting to the battery terminal. You nedd to call Lenovo Support at 18774536686 then option number 2 for repair of the computer.
Thank you for using Fixya!
Feb 21, 2011 | Lenovo IdeaPad S10-1208Uw Netbook
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
Jan 28, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
Lenovo 3000 N200 Notebook Logo
502 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
