Question about Garden
The blades on my hedge trimmer stopped moving even though the engine is running
    Problem Solver:
  • 6 Answers
There is a cable that runs down the shaft and some times when grass gets built up on the head it will overheat and melt the plastic piece that runs the blades. you will have to get a new shaft
Posted on Feb 25, 2010
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
I have a petrol hedge trimmer TRY26PHTA. The engine will start fine but the blades will not move
If the engine starts 'fine" then it has not seized.
Many, if not most, hedge trimmers are , for safety, equipped with a "CENTRIFUGAL CLUTCH" between the engine and the blade to prevent blade operation unless the engine is at full RPM.
IF your machine is so equipped, it's possible that the clutch is worn and slipping so badly that the blade can't move.
Jun 11, 2014 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Engine running, blades not moving
There is a big steel cable/wire type thing e in side the tube of the machine connect motor too head and itz broken look at small engine shop online
May 31, 2014 | Husqvarna 122HD60 Hedge Trimmer
Hedge trimmer blade not moving
adjust blade screws by backing off half a turn...still not working clutch could be worn out..
Oct 08, 2013 | Garden
Homelite Hedge Trimmer HT-21 engine runs, but blade doesn't move
check the plastic gear where the engine meets the trimmer head
Aug 07, 2012 | Homelite Garden
Engine runs great, accelerator responds perfectly, but the blades stopped moving. Any ideas?
Ensure blades are sharpened. If there are burs on blades they can seize.
Blades should be lubricated with WD40 , waste oil or other lubricant.
The bolts holding the two blades together shouldn't be too tight.
Apr 30, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Hedge trimmer won't start. No jam or bend in blade. Battery is re-charged. Just won't start! Reset button isn't doing a thing!
Take the battery off. Now see if you can move the blade. Sometimes the blade can get to a point where it acts as though it will not run. If the blade has moved, reinstall the battery and see if it goes. I had you remove the battery for safety...Lee
Aug 23, 2009 | Garden
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
356 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
