Question about Nokia N70 Cellular Phone
Memory card Hi, This is Yogesh, i want to ask u how to move application data & documents in memory card.
  • 94 Answers
U must have mmc card reder.
or a data cable of or mobile.
if u have a datacable of ur mobile then connect it with ur pc and miobile.
then u have seen some options on ur mobile screen one of theme will data transfer mood like this
select that and see in ur pcu will find a new drive and now u can move data & doc.
ok
sir bye
Posted on Feb 21, 2008
Tablet claims to be out of memory but uninstalling apps doesn't free up any space. Even with 32GB SD card is says not enough room for new apps.
Memory in this case doesn't refer to the memory in your SD card, but in the phone or tablet itself. Biggest culprit is photos and music.
Uninstalling apps should free up space. Reboot phone after removing items to record the true memory available.
Sep 22, 2015 | Samsung Galaxy Tab 4G 10-in 32GB WhiteWith...
I'm having this problem in my nokia e5 : My memory
If the phone notifies you if the phone memory is getting low. To free phone memory you have the following options:
  • Move data that you want to keep to an alternative memory (mass memory or memory card, if available) or to a compatible computer.
  • Remove data you no longer need.
Use File Manager or the respective application in your phone to remove data or to move data to alternative memory as described in the user guide. Typically you first mark files to be removed or moved and then you select the corresponding option (Delete orMove to folder).
Use Nokia Ovi Suite to move data to a compatible computer.
In order to free phone memory, you could remove or move the following:
  • Messages from Inbox, Drafts and Sent folders in Messaging
  • Retrieved e-mail messages from the phone memory
  • Saved Web pages. Clear the web browser cache to free some phone memory (e.g. select Options > Clear privacy data >Cache).
  • Saved images, videos, or sound files (in Gallery, Photos,Videos or Music player)
  • Contact information (in Contacts)
  • Calendar notes (in Calendar)
  • Downloaded application packages
  • If there are applications which are not needed any more, uninstall them with Application Manager
  • Any other data that you no longer need
If you are deleting multiple items and any of the following notes are shown: Not enough memory to perform operation. Delete some data first or Memory low. Delete some data, try deleting items one by one (starting from the smallest item). After deleting data, restart (power off/on) your phone.
Tips: Use the memory card or mass memory instead of phone memory in the Camera or other applicable applications in case the selection is available (e.g. via Options > Settings >Memory in use).
I hope this helps!!
Aug 06, 2017 | Cell Phones
I have a nokia c5-03 and i get the message:not enough memory to perform operation.delete some data first but i cannot enter anywhere(in settings) or application manager,etc because i get this error. also...
I hope this helps!!
Aug 06, 2017 | Nokia Cell Phones
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
My phone samsung b7722 duos.Opening the files,images, capture the camera and Dictionary at the time this mobile was asking ( Not enough memory close sum application and try again later )
y phone samsung b7722 duos.Opening the Multi software at the time this mobile was asking ( Not enough memory close sum application and try again later )
Apr 20, 2011 | Samsung Star GT-S5233 Cell Phone
I upgraded the Android system for my sanyo zio and now i can't recieve any text messeges cause it says that the memory is full and it also says that my phone memory is full eventhough iv'e been erasing...
It seems most of you applications are stored in the Phone Memory and/or your application data is taking up lot of memory. You actually don't have to erase/uninstall applications. Please consider performing the following steps:
  1. Go to Settings --> Applications --> Manage Applications. In this Menu you'll be shown a list of applications. Use the Menu Button to "Sort by Size" and get a list of the applications sorted from high memory usage to low (phone memory). Once this is done, you'll be able to view the memory being used by each of the applications. Click on the applications which you see are consuming more memory and then use the "Clear Data" button to clean up the data being stored by the applications to free up memory. This clears up any cache, cookie, temp files associated with the applications. Depending on your android version, you may also see an additional button "Move to SD Card". The best option to get more space would be to use this button and move the application to the 4 GB SD Card storage.
  2. Optional Step if you do not have "Move to Phone/SD Card" option available - From the Android Market, download and install "App 2 SD Free". Once done, this application should help you free up a lot of space by moving applications from your phone memory to the SD card.
Hope this was helpful. If so, please consider rating this solution.
-thanks,
M
Mar 09, 2011 | Computers & Internet
Keeps saying low storage need to do an update on phone as i havent anything stored opn it an i have 4gb sd card
It seems all your applications are stored in the Phone Memory and/or your application data is taking up lot of memory. Consider performing the following steps:
-thanks,
M
Mar 08, 2011 | HTC Desire Cell Phone
Hi, My N73 shows Memory full & ask to delete some data, except the phone book i have deleted all the other data, but still the problem persist, i am not able to send or receive mgs's nor view the...
Its mean phone memory is full, you can make some space by deleting some installed application. Delete also all cache/history in your browser. If the problem persist, reset your phone to factory setting after put off your memory card. After resetting the phone, your phone memory will be empty again and you can reinstall your previous application. Avoid to install application in phone memory (always install in memory card).
Hope this help.
Feb 25, 2011 | Nokia N73 Cellular Phone
N70 - Music player memory & Operator logo
The N70 only has 22MB of built-in memory, and all incoming bluetooth files go directly to the onboard memory (inbox) before you can copy or move them to the memory card. Try freeing up some of the system memory by using the "move to memory card" option and then try to get your song again. :)
Regarding the other issue you are having, the oplogo should be located at the location below, and is always displayed. If you want nothing displayed there, you can replace the image with a solid color of the background of your choice by editing in photoshop or similar program.
This is a 97x25 pixel file, and is named according to your Country Code, Network Code, and Subnet code. There may be several files located here, as they change when you 'roam' around, and you can edit any number of them to your liking.
Hope this helps, please let me know if you have any questions!
Music player- Not enough memory to perform operation, delete some data first.
Nov 25, 2007 | Nokia N70 Cellular Phone
Hi..i have a problem with the memory.
Some times phone memory data has support files in memory card and vice versa. Your 6233 have just 6MB phone memory. Try to transfer the phone memory data to memory card or PC. Check which made your memory full. Check whether you have Blue tooth data in inbox. if your Phone memory is full you cannot perform some phone application. try to erase some un neccessary data in phone mode itself withourt connecting to Pc suite applications. after data removal try to connect with Pc suite. Now you may transfer your phone data. if problem still persists contact authorised service personnel. All the best !
Nov 11, 2007 | Nokia 6233 Cellular Phone
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
