Question about Dell 924 All-in-One InkJet Printer
My Dell Photo AIO Printer 926 will not print.
When I power on the printer I get message "clear carrier jam and then press check". Have cleared all paper. WHen I hit the "check", it looks ready to go but when I print it displays "printing" but never prints. Printer is only couple of years old with little home use. My daughter has same printer with same problem. Tried sending a test print page, printer says printing but never prints. Try to copy, display says coping but never creates the paper copy.
Arius
  • 446 Answers
SOURCE: How to clear carrier jam in Dell Photo All in One 944
simply open up your printer and see if there is any residual paper that get stuck, in some case if you can find some small miniature piece of sensor it might cause a erratic sensing that there is a presence of paper while there isnt, try to clear this or clean.
paper jamming indicator means there is some paper in the paper path, unless otherwise ou clear this up you cannnot print.
after you may need to power down or restart your printer once again
cheers
Posted on Nov 27, 2008
rhoncruz
  • 134 Answers
SOURCE: Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Posted on Dec 02, 2008
  • 514 Answers
SOURCE: carrier jam on 926 dell printer
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for code 1200 in the middle of the page. good luck!
Posted on Feb 28, 2009
Vivektj
  • 55 Answers
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Posted on Mar 02, 2009
pineworks
  • 4041 Answers
SOURCE: paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
Error message clear carrier jam, when I opened the top of the Dell Photo 926 a long clear strip fell out, What do I do to fix this.
The long clear strip is the encoder strip that the cartridge carriage reads to know where it is in the printer. It should not have just fallen out. There should be a small hole at each end of the strip to attach it to points in the printer. If one of those holes is broken you might as well get a new printer. Paying someone to buy a new encoder strip and install it will most likely cost more than the machine itself.
Sep 28, 2010 | Dell 926 All-In-One InkJet Printer
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
Error 1203 for Dell Printer AIO 926
Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
Not working see bottom
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
May 13, 2009 | Dell 926 All-In-One InkJet Printer
Won't copy, error message 2200 pops up and says to check manual. Manual doesn't reference that error message.
Try this - turn off the printer.
Remove the power supply.
Press the power button for 15 seconds.
Then plug it back in.
That should've cleared the printer!
Apr 17, 2009 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Apr 15, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Dell926
Clear Carrier JamThese are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges.
Regards
Chittaranjan
Dec 14, 2008 | Dell 926 All-In-One InkJet Printer
Dell AI0 926 All in One shows Clear Paper Jam with no paper in it.
I put my hand inside and found something clicked just below the right of the first two rollers. THen it worked i think whatever clicked must have gotten stuck but i dont know why
Oct 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Dell 924 All-in-One InkJet Printer Logo
216 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
