Question about Minolta magicolor 2400W Laser Printer
Error flashing, Status 'Put Cyan Toner' - but toner showing 100%
I have a much used 2400W. Recently is has a strange fault and refuses to print. The error light flashes, and the red Status screen says 'Put Cyan Toner' (it has also said put black toner), but the supplies status says 100% for Cyan (I know it is less than that), the toner replacement light is not flashing.
What's going on - is it the end??
Any help gratefully recieved as this has been a damn fine printer and don't want to give up on it!
  • amadey Mar 14, 2008
    I have a same problemm
  • GI Joseph Oct 22, 2008
    Same problem - I"ve totally cleaned the unit, and the toner switch reader. I tried switching out the chip with a new spare I have still no go. So now I"m left with swapping out the 3 prong toner chip reader but cannot find it anywhere, HELP!! Thanks for your time.
    New Friend:
  • 16 Answers
I think someone touched on this solution briefly, but here is how you fix the problem.
Clean the 3 copper contacts on on the green chip with an eraser or rubbing alcohol. The chip is on the right side of the cartridge. You will probably see black lines on the contacts. This will fix the issue about 90% of the time.
If it doesn't work you want to clean the chip reader. This is the switch that CCSStech was talking about. It also sits on the right side of the printer almost under the toner cartridges and has three prongs sticking up. Clean those prongs with alcohol. If that doesn't work replace the switch. If you are using refilled cartridges, the chip on those sometimes doesn't work. In that case have the manufacture of the refill replace the toner for you.
Posted on Jul 17, 2008
Order a new "Button", the small part that has 3 contacts that touch each cartridge as they rotate by. It is a small black switch that can be easily accessed by removing all cartridges. It pops out easily, be carefuld not to damage the wires that attach to it. You may find the part at: https://www.nationalparts.com/store/cart/purchase1.asp?pid=6984&XPR=0666058409690586098F076D0B0666058409690589098C076B0B
There is a min. $15.00 charge, so buy 3 of them at $5.00 each, plus shipping, you will spend $28.22 (ground shipping). Works for me!
Posted on Jul 13, 2008
Hi
I eventually solved it in 2 ways. Firstly it needed a damn good clean. There was toner everywhere and I think it was on the electrical contact bits (that's not a technical term) between the toner cartridges and the printer. It was getting confused and kept thinking it needed more toner.
Ultimately the best longterm solution was to buy a nice new magicolor 2530DL as it uses the same consumables. It was only when I stripped the old one for parts that I realised how dirty it was - so get cleaning!
New printer is great and so far behaving perfectly
Posted on May 21, 2008
I am having a similar problem. I replaced the fuser unit on my printer and it starts going through the warm up then it flashes error constantly. There is no jam and the jam sensor is ok.
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
Xerox phaser 6180. Printing 3 blue horizontal lines spaced evenly apart on printed page. New toners. Could it be fuser? transfer roller?
Just because they are new toners, doesn't mean they can't be faulty.
Faults that show in just a single colour are almost always related to THAT colour toner cartridge.
TRY THIS
If you still have your old cyan toner, swap the chip from your new toner and put the old toner in the printer, then test.
If the lines are gone, it's the NEW cyan toner cartridge.
Jan 07, 2011 | Office Equipment & Supplies
Minolta 2400W errors
GO and get 4 Konicminolta image units one for each color and replace them do not use third party. NEVER ever use a vacuum cleaner the static electricity can cause sensors to go bad !!!!!!!!!!!! might have destroyed the chips on the image units SO recommend get all new hopefully you did not destroy the control board with static electricity
Apr 27, 2010 | Minolta magicolor 2400W Laser Printer
Samsung CLP-300 refuses to acknowledge new toner. The toner is brand new from Samsung. Test page shows the colour being used perfectly in the Samsung logo. The light just continues to flash and the...
you may press and hold the button for 5sec and let go to print the supplier info.
If it still show @ 0% you may want to check with the shop you purchase to get an 1 to 1 replace.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Minolta 2430dl, cyan, magenta, and yellow toner cartridges all show empty. Black shows 42% remaining. How do I get printer to print?
Some printers will refuse to print _anything_, until you replace/refill _all_ of the empty toner cartridges. So, replace/refill.
Dec 30, 2009 | Konica Minolta Office Equipment & Supplies
Minolta 2400W - Put cyan / black toner
hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Jun 28, 2008 | Konica Minolta magicolor 2400 Laser...
Cyan Toner always prints faded.
It is the developer. All colours should be changed at the same time. This can be accessed via the right hand side of the machine, when you remove the cover. (where the output tray is)
Feb 06, 2008 | Xerox DocuColor 12 Color Copier
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Minolta magicolor 2400W Laser Printer Logo
358 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
