Question about Ingersoll Rand Air Compressor Maintenance Kit for TS7 Air Compressors
My tow behind air compressor ingersoll rand 185 engine starts but air wont flow...why
    Champion:
  • 243 Answers
Press load button or toggle switch
Posted on Feb 08, 2010
I have an Ingersoll Rand UP6-7.5 air compressor. When you turn it on the fan for condenser runs but compressor wont start
Yes it is located in the intake air hose or air cleaner housing of the engine, It is called the "IAT" Intake Air temperature sensor"
Jan 13, 2017 | Ingersoll Rand Air Tools & Compressors
How do you get the tow hitch off the 185 ingersoll air compressor
standard fitment is a round ring
and a jockey wheel
you will need to look at
compressor trailer frame warp
towball weight is wrong
the tow vehicle tow bar for a bend
the axle balance and ball weight of compressor
Aug 06, 2016 | Ingersoll Air Tools & Compressors
Testors Blue Mini Modelers Airbrush Compressor
Air compressors are rated for a maximum pressure and maximum output flow. Your description implies more air is going out of the compressor than it's designed flow rate. Check for a major leak at hose fittings or around the compressor. If this is an old unit, a compressor gasket could be cracked or broken.
May 31, 2014 | Ingersoll Rand - Rand Type - 30...
Where is oil cooler
Hi not totally familiar with this compressor but the oil cooler will be in front of the air intake vents with the cooling fan behind it
Mar 07, 2014 | Ingersoll Rand P185WJD Platinum Series Air...
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
My 185 ingersoll rand tow behind compressor shuts down when I open the valve to blow out sprinkler system...why
I worked at a tool rental store while attending college and noticed that IR compressors would shut down for a variety of safety reasons. Most common was low oil (engine), high temp (engine) and high air temp (compressor) and safety valve measuring access flow or free flow as if the hose becomes disconnected from tool (OSHA safety). Check all the safety control features of your unit for possible answer. Good luck
Oct 12, 2010 | Ingersoll Air Tools & Compressors
Need to know what compressor oil to use for 185 ingersoll rand compressor
The parts store,napa sells a air compressor oil that is compatible,It is called simply,air compressor oil.It is made just for compressors.
Oct 06, 2009 | Air Tools & Compressors
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
Apr 06, 2009 | Air Tools & Compressors
Ingersoll Rand Air Compressor Maintenance Kit for TS7 Air Compressors Logo
1,811 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
