Question about Dimplex Heating & Cooling
No heat heater is working without heat
  • 1,476 Answers
Could you supply more information please. Then I may be able to help you.
hardrocko
Posted on Feb 07, 2010
Does not heat up and timer not working?
send brand name and model number so i can help you,also if it's on time dry it should count down even without heat if you have it on more or less the timer will not move without heat.heat comes on until heater cycles off when the heat is off the timer will advance a little,when the heat comes back on the timer stops advancing,it will do this until the clothes are dry.
Sep 15, 2013 | Dryers
Heater does not come on, Radiator fluid full. Fluid heats, heater does not work blower works heater does not get hot or even warm.
Probably air locked. check to see if one of the hoses leading into heater is hot. Other cause could be heater solenoid control valve faulty. Very unlikely that the heater matrix is blocked. Easiest way to bleed heater is to remove hose's when car is cold and GENTLY flush through with garden hose and push hoses back on when full of water, so you know you have a heater full of fluid. Hope this helps
Jan 11, 2011 | 2000 Jaguar S-Type
The heat in our 1998 continetal doesn't work. We replaced our thermostat. Still on heat. The a/c works fine. The vehicle run fine without any sign of over heating. We can't undrestand why the car's heating...
Two possible reasons, one is that your heat control valve that directs hot coolant to the heater core may be stuck or blocked. Two, you may have an airlock in the heater core that prevents water getting in to the heater core. You need to let the air out by loosening the upper most hose that feeds the heater core.
Dec 15, 2010 | 1998 Lincoln Continental
Drivers seat heater no longer heats as it used to. Passenger side heater still works. Is there a fuse that controls the heater function under the seat?
Without knowing what vehicle you have Im just guessing.The element that heats up is a possibility that it may have a broken wire and the element needs replacing
Sep 07, 2010 | Chrysler Sebring Cars & Trucks
I have an aqualink rs and my spa heater isn't working. I checked the propane and it is full. The heater was working 2 days ago. Now I turn spa and spa heat on the filter pump comes on and the red light...
If the Aqualink is calling for heat then the problem is most likley in the heater. Without more information I can't tell you much more but if nothing has changed in the last couple of days. Before you call anyone be sure to clean your filter and baskets. The heater need a set amount of pressure to run and if things are dirty it won't get that pressure. Good luck.
Mar 12, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Amana electric dryer will not heat....LEA60AW
check your wall vent to make sure it's not clogged,also check the fuse on the heater box it may have blown,without the fuse the heater will not work,you can check it with an omns meter-mike
Feb 23, 2009 | Dryers
No heat
try replacing the heating core mine is the same way and that is what's wrong with it
Feb 02, 2009 | 1994 Dodge Grand Caravan
Over heating
The brand new water pumps are junk. I put a reman water pump on and it works great.
Jan 10, 2009 | 1995 Chevrolet Monte Carlo
Testing a hot water heater
I would try a continuety test on the element.  You should get no resistance.  If the water heater has been sitting for any real length of time, then it is probably better to just replace, instead of tryin to reuse, especially since you don't want to shower/wash is stagnant water...
Hope this helps
Jan 08, 2009 | Water Heaters
No heat after changing thermostat.
remove the heater core lines the two hoses that go to the heater core, take a splice tube either metal our plastic your part store will have either one. take the splice tube and install it in one of the lines add some hose to that tube make the hose long enough to run out side of the engine compartment and on to the ground. take the other hose and install a flushing tee, hook up to a garden hose and trun the water on . what you are trying to do is flush the heater core , you are also looking for blockage off the heater core, if you little to no flow i would suggest replaceing the heater core
Dec 16, 2008 | 1991 Ford Escort
Heating & Cooling Logo
124 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
