Question about Olympus Stylus 850SW Digital Camera
Pls help i have a problem with my olympus camera stylus 850sw, when I would turn it on it says write protect.what will I do...pls help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position nearest the contacts enables writing, the position farthest from the contacts protects the card from writing. If the slide is already in the proper position, try sliding it fully the other way and then back again.
If that doesn't work, try a different card.
Posted on Feb 06, 2010
Olympus Stylus 850SW viewfinder and photos pink and blurry
Pink photos are usually caused by White Balance being set wrong. You should see in the menu the WB icon. Change the icon to the symbol of the sun. Or.... just reset the camera back to the default settings by going to the camera reset in the menu. If this fails, then your picture sensor is needing to be replaced.
For the manual, go to the following site:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1365
Jul 05, 2014 | Olympus Stylus 850SW Digital Camera
My new olympus stylus 850sw is not working. The flash settings do not seem to work, and all the pictures turn out either really dark, or a bright white screen. I've altered all the settings, and nothing is...
You could have a problem with the board of the camera. I hope you did not drop the camera. If what you say is happening try to restart the computer of the camera by removing the main battery. It also has a reserve battery and I suggest you remove that too. In about an hour put the batteries back and see if the camera has reset itself. If it does not work I hope you applied for the extended warranty and just send it back to the camera shop if they handle it or directly to Olympus. Good Luck
Jan 07, 2011 | Olympus Stylus 850SW Digital Camera
My camera olympus 850 SW the lense turn on violet color thats why when im startng to video or take a picture its color is violet..
i don't have the solution but i experienced the same problem on my olympus 850sw
the images turns violet and the pixels are distorted
never see this kind of error ever a camera had
Oct 18, 2010 | Olympus Stylus 850SW Digital Camera
My Olympus Stylus 850SW won't turn on. Thought it was a drained battery, got new battery, then thought it was my charger. Bought new charger. Battery is fully charged, camera still will not turn on.
Link
Good day,
Link above leads you to the Stylus 850SW manual-see page 62. Please make sure that you are using Olympus Lithium Ion Battery only, as this is the only battery the camera is accepting. Using exhausted battery will make the camera to turn off.
If the problem still persist, kindly contact Olympus Help desk for more details.
Regards.
Aug 05, 2010 | Cameras
Blurry lens after using it underwater
Sadly that symptom indicates that the camera is broken.
The device's seal protects both from the condition that you are seeing, but also protects the internal circuits from moisture.
If water has gotten inside the camera, I would pursue returning it and getting a replacement from the company.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 29, 2009 | Olympus Stylus 850SW Digital Camera
After charging the battery i put it in my camersa and it reading batttery empty
This happened to me before and its because i put the battery in the charger the wrong way up. Make sure you put it in so that the side with OLYMPUS in it in big letters is facing up!
Apr 20, 2009 | Olympus Stylus 850SW Digital Camera
We can get in to the panorama menu : we cannot get to combine in camera 1 or 2 camera stylus 850sw HELP! yep, i can get to the panorama mode because i bought the olympus card, but i also can only combine...
Put the camera (turned on) in normal shooting mode then press the ok/func button (middle of the navigation buttons) at the bottom will appear PROGRAM AUTO push right navigation button so the P illuminates not the AUTO press ok/func. You should now be able to select panorama in the normal shooting mode menu press func/ok then select combine in camera then select ok/func.
Good luck- I fretted over this for two days till finally getting it-and you the manual does not help!!!!!!!!!
Miguel
Venezuela
Feb 05, 2009 | Olympus Stylus 850SW Digital Camera
Is the Olympus 850sw digital camera waterproof?
You probably know by now that the 850SW is waterproof, shockproof and also stands up in freezing conditions. I am just writing because I am very happy with mine and would highly recommend it for your active boyfriend. We have gotten many great pictures with it in the water and the kids have been pretty rough with it at times.
Olympus also has newer versions of this camera, the 1030SW and the 1050SW. I saw the 1050SW today at Costco for just 229.99.
Nov 17, 2008 | Olympus Stylus 850SW Digital Camera
Olympus Stylus 850SW Digital Camera Logo
376 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
