Question about Kitchen Appliances - Others
It keeps on tripping the electic
I have a dualit electric kettle but everytime i turn it on it trips the electric to the house. i have replaced the fuse and looked at the base and made sure all the wires are attached correctly. can you help?
    President:
  • 2,468 Answers
Sounds like you have a heating element touching the case or a bare wire in the electrics path shorted to ground and tripping the breaker,re-check all wires and if it has a replaceable cord as in it plugs and unplugs from the unit check this for a short
Posted on Feb 06, 2010
My tefal keeps tripping elcb in fuse board what could be wrong
Next time it happens and it trips.. use a dry towel to unplug kettle, just in case.
Is the base wet? Check the kettle for cracks. Check the cable. Is it damaged? Try replacing the fuse in the plug. Is the steam that the kettle produces affecting lighting or other electrical items around it? Try moving the kettle to a different location.
Aug 05, 2015 | Tefal Irons
Cannot take dualit plug apart
Remove the small silver Dualit sticker from the pin side of the plug. There is a small screw inside that will undo the plug :)
Apr 04, 2012 | Kitchen Appliances - Others
Kettle has just suddenly tripped the electricity. Tried changing fuse and different plug socket but still tripped. O oh!
This is because there is a current leakage between the live and earth terminals of the kettle.
You see, if current leaks from live path to earth, you will get an electric shock when you touch the outer metal surface (because the metal part is earthed). To protect you, the trip switch will cut off the electricity supply.
You can try drying the kettle in hot sun. This is because the current leakage is most probably due to water leaking in to the circuitry.
You can try replacing the heating element, if it is available in the store. Otherwise do not use it. That's better for your safety.
Jul 22, 2011 | Dualit 72024 Cordless Electric Kettle
My kettle keeps blowing the circuit
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle.
Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
May 28, 2011 | Dualit 72300 Stainless Steel Cordless...
Dualit element gone
Very very dificult to replace. I have try it but then I have purchase a new complete base with element.
Apr 30, 2010 | Dualit 72102 / 72100 Cordless Electric...
I have a Kenmore 300 series elect. dryer that keeps tripping 30 amp breaker. Have already changed breaker wiring going from box to dryer and installed new motor.
Check your load/AMP capacity.
If you have other electrical appliances on ie. Iron, Heater, toaster, Kettle these will contribute to the over loading problem.
Old homes sometimes only have 40-80 amp capacity
Apr 19, 2010 | Dryers
Dualit glacier blue kettle spare lid
Our kettle has just broken so if you'd like our lid? - if so I'll pop it on ebay?!
Apr 04, 2010 | Dualit 72102 / 72100 Cordless Electric...
Whirl pool elect dryer keeps tripping breaker
Ok, this is the result of a failed High limit thermostat. you should replace this failed device asap.
Check for continuity in the thermal fuse as well. replace if no continuity is found.
May 31, 2009 | Whirlpool LEB6300 Electric Dryer
My red plastic on switch has snapped
you can buy a replacement from here
http://www.spares2go.co.uk/browse-DUALIT-72001-ON/OFF_SWITCH_-_RED-m125-p159253-s161139.htm
£6.95.
Jan 07, 2009 | Dualit Axis Cordless 1.7 litres Cordless...
Kitchen Appliances - Others Logo
289 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
