Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
When I turn my TV on it turn back off
When I turn on RCA projector TV 10 years old, the light on the power switch comes on for a second and turns off.
what do I need to do
5 Suggested Answers
SOURCE: won't turn on
Replace the small signal board and take the eeproms off the old board put on new board to avoid convergence alignment and geometry problems
Posted on Jun 21, 2007
SOURCE: TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Posted on Feb 02, 2008
Slinteriors
  • 8617 Answers
SOURCE: My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
Posted on May 11, 2009
SOURCE: 52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Posted on Jan 30, 2010
There is a only a vague picture on the screen. There is sound but no picture. And the problem is not the setup/tv menu. What is the problem. The TV is only one year old.
As a preliminary step, try unplugging the power cable and then push the power button continuously for 10 seconds (this should drain the flea power from the capacitors inside your monitor). Now plug the power cable back and turn on the TV to check.
This can happen when the back light / the back light circuitry is not working which actually lights the LCD panel in the monitor. Please check for the warranty for this product if so immediately contact RCA tech support. If the monitor is out of warranty then its time you approached a local TV / Monitor repair technician.
Dec 22, 2010 | RCA L26HD35D TV
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
I stored my TV for 2 years and when I went to turn it on the green power light came on for 10 seconds then turned back off. That's all the TV does now. The screen is blank and the TV does not come on.
Try this:
1- Unplug power for 10 minutes.
2- Plug in and turn on again.
if it doesn't turn on then The power supply is bad. Usually the power supply unit can be replaced, but you have to open the case to see how it looks like before order the same one.
Jul 03, 2009 | Mitsubishi HD1000U DLP Projector
Sanyo PLC-XU33 image displayed for 10 seconds then turns off
Owner decided to upgrade to a newer projector. Lamp was too expensive.
May 07, 2009 | Sanyo PLC XU33 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
