Question about Sharp 25J-M100 TV
SHARP TV - MODEL 25j m100
On the back of tv, the cable connection adapter has been loose for some time, but now it has come undone from the inside.
I took the cover off the back of tv, saw where the connector belongs, but the area where it comes through, the hole is oversized, oblong, I'm assuming it's from moving the tv around that's caused this.
It's a great tv, the picture use to be great, bright colors, sharp clear pictures.
Is this repairable, and can you send instructions for repairing it.
Thanks
D.G.
  • 579 Answers
The RF jack is solder directly into the tuner module and as long as it did not break the circuit board inside that it connects to, it can be repaired . Takes a lot of heat though to solder the jack to the frame of the tuner. Sometimes I use 2 irons to get it hot before the plastic guts of the jack melt too bad. Also is sometimes hard to cram the jack back into its mounting hole, may need to file it out some. The makers don't solder these on they are just pressed in and crimped which is why they break off so easily. I recommend using the push on type cables to avoid this problem. Don't forget to solder the center conductor into the tuner board.
Hope Ya Fix It!
Posted on Feb 21, 2008
How move board from set
What do you mean? Which board do you want to remove? If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 24, 2015 | Sharp 25J-M100 TV
Sharp instruction manuals
Contact Sharp customer service on the web..Sharp website...give them the model number you gave us.
Sep 04, 2014 | Sharp 25J-M100 TV
Tv showing with lines, screen blank but hearing clearly.
its white retrace fault, check video section or crt internal short problem
Apr 23, 2014 | Sharp 25J-M100 TV
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
Tv switches on for about 3 seconds ,then switches off
The capacitor(s) of TV power supply spoiled and need replacement. Please check it out and get replaced. The purpose of capacitor is to stabilized power supply.
Regards, vote please, Jay
Jan 20, 2011 | Sharp 25J-M100 TV
Input jacks in Sharp 25J-M100/ Pc to Tv cable
You can purchase an s-video to composite video connector to view your Dell computer's television output on your sharp CRT television, though the image will be a bit blurry because of the connection and CRT technology limitations, though streaming video probably can be seen just fine. An example of an s-video to composite video connector can be found here: http://www.svideo.com/svideorca.html
but you probably can find a cheaper priced unit somewhere else, maybe even at radioshack.
I hope this helps!
May 18, 2009 | Sharp 25J-M100 TV
Broken ant/cable connection on Sharp TV, model 25R-M100
yes u can buy them at a local radioshack or similar business
Apr 28, 2009 | Sharp 25R-M100 25" TV
Code for universal remote
One website (Universal-Remote.Net) , says the setup code for a Sharp TV, using a Philips universal remote, is one of the following numbers: 002, 013, 014, 111, 502, 712, 812, 813, 913, 918.
Hope these numbers work for you. Please take a moment to rate this info, using the rating system below, after you have tried these numbers. Thanks.
Jul 15, 2008 | Sharp 25J-M100 TV
Earphone
hi there, some tv model have the option for earphones, others don't, ty
Dec 29, 2007 | Sharp 25J-M100 TV
Menu
to acess the menu push the channel up button and the volume up button on the front panel or the channel down and the volume down.and the menu will appear.but you can get the originald remote at www.partstore.com good luck
Jan 16, 2007 | Sharp 25J-M100 TV
Televison & Video Logo
209 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
