Question about Spire STARS-420/2 White grease Thermal Cooling Paste 2Gram Tube Injection tube : 150×5×5mm.
Thermal Paste Need to know how critical thermal paste is to installing new CPU? I neglected to get some along with my new CPU and I can't find any locally. Is there any house-hold stuff that can be substituted?
  • edzharman Feb 13, 2010
    Found thermal paste at my friendly local Radio Shack for just $3.16. Thanks, anyway.
    Problem Solver:
  • 5 Answers
From the word itself it is a thermal paste that can hold the CPU and iot helps out to prevent the heat coming from the processor, when the cpu fan operate/spin it also that helps that processor to cool down.
You may try a toothpaste as a substitute for it you will need a "white base toothpaste" just put only a small amount into it.
Let me know for any clarification
Posted on Feb 06, 2010
Testimonial: "You're advice was direct to the issue and very helpful. Thank You Very Much!"
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
OMG! Do not listen to Jhulmar Ocampo,
That is a sure fire way of frying your new processor.
Only use high quality thermal compound (not your radioshack stuff you have got now)
You might think you are saving a few pennys by buying cheap. But you have to ask yourself this. Is it worth frying my new, hundreds of pounds/dollars worth of cpu because of saving a few pennys?
Thermal grease is definitely a MAJOR part of a modern computer's cooling system.
Do yourself a favour and get a top name brand e.g. Artic silver or the ceramic version the same company does.
Posted on Aug 19, 2012
Thermal paste is needed because the surface of the processor and heat sink are not perfectly smooth. if you examine with a high power microscope, you will realize there are small hills and valleys. With no thermal paste, the heat transfer is limited to the small contact points that result. With a filler, that is heat conductive. a thermal heat path is formed across the whole heat contact area not just the high spots.
at first the thermal paste was silicone grease. anything like this will work, even Vaseline. Later the silicone grease became white, this was because of the filler Zinc Oxide. a good heat conductor and poor electrical conductor.
bottom line the thermal paste greatly improves the ability to draw the heat out of the processor.
Posted on Jun 13, 2012
Tip
THERMAL PASTE helps
Maybe you have encountered problems like your computer freezes suddenly and you try to find solutions to it by troubleshooting your hardware or software installed. And after troubleshooting for hours and you are 100% sure that all your hardware and software are working just fine.
But you have never tried to look or never guess that between the Heat Sink or CPU has a solution that is put between them to be able to cool the processors/components. It is called Thermal Paste (other names: thermal grease, heat sink paste and etc.).
Thermal Paste helps the cooling off of components and draws heat away from heat sink/cpu. It is really a big help and can increase efficiency in your computer systems.
If you haven't try or see Thermal paste in your computer, try opening your system it is found between your heat sink and cpu, the substance that is applied between them.
It solves computer freezes.
on Jul 15, 2010 | Computers & Internet
Is any problem may occur , without thermal paste in PC ?
Yes, you need thermal paste for 100% and you need good thermal paste for this CPU, this processor is - Thermal Design Power ? 125 Watt
Nov 15, 2012 | Computers & Internet
Laptopmotherboards
Just take the laptop apart and install the new board. Be sure to remove components you need from the old board such as the cpu, memory, heat sink, etc if they are not on the new board. Also remember to apply a fresh coat of Thermal Paste around the cpu and heat sink.
May 30, 2012 | ASUS Eee PC 701 Notebook
New thermal paste after a month
Anytime you take the heatsink off of a CPU you should remove and replace the thermal compound. If you didn't, then there's no need to worry about it.
Apr 13, 2012 | Computers & Internet
Emachine w3609 cpu overheating
Easy Fix.. Computers over heat because either a fan is not working, Dust has clogged the vents around the fans, CPU and Heat Sink or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep it cool.
Remove the cover from the computer and set it aside then turn the computer on. When you hit the power button to turn on the computer make sure you hear and see the constant blowing of the fans. There will be a fan that is on the Power Supply where the power cord plugs in and a fan on top of the CPU and Heat Sink. If not, replace it. If the fans are ok get a can of compressed air from a local computer store and blow out the dust from the fans, power supply and all throughout the computer. In order to apply Thermal Paste on the CPU and Heat Sink you will have to remove the fan that sits on top of it and is normally secured by screws or some type of latching device. Once the fan is removed you can remove the heat sink and it too will be secured by screws or a latch catching device. Clean the old paste off the heat sink and off of the area it sits on. Apply a fresh coat of Thermal Paste to both and reassemble. Thermal Paste is available at local computer stores for under $20
Mar 21, 2012 | Computers & Internet
My pc mobo is intel 915gav. processor is P4 pinless running with 1 gb 400 bus ram..after a new installation of win xp i worked hours continously..but in in next morning when i turn on pc after running
Hello
There will be a thermally conductive paste [Heat sink compount], a white tooth paste like substance, must be applied between the heatsink and the CPU. It is a must. If you have replaced, or unlocked the heat sink metal, and haven't applied this thermally conductive paste, proper heat transfer from CPU and the metal heatsink will take place, and the CPU will overheat, and finally go out.
Music videos are large files, which apply a great load to CPU, as processing video is a great task for CPU. Temperature must be below 40 degree centegreade, at any instant.
Just unlock the heatsink lock, take out the CPU heat sink out, and apply some heatsink compound [silicon grease] and retry. If you hear a beep sound after 3 seconds or so, after swithch ON the system, you have won. OK.
http://www.dataentryjobs.us/67948.html
Feb 22, 2012 | Intel D915GAV Motherboard
In thermal my system fan speed has a red dot what does this mean
I believe this means you need to upgrade your CPU cooler fan!Usually it would react this way when a thermal event is takin place.In which case,your PC is getting bad thermal readings,so make sure you have proper air flow in the computer as it may be the reason for your thermal issues.Otherwise you would have to manually remove your CPU,remove the current thermal paste and apply new thermal paste carefully in the designated area specified by the manufacturer!-Hope this helps!!!-CB
Dec 17, 2011 | Acer Computers & Internet
Cpu over temperature error cpu temp : 39 to 101 mb temp : 30 to 100
First step would be to check all cooling fans are running correctly. Second blow out the dust and debris from inside the computer. If the cooling fans are not running correctly you will need to replace them. Thrid have you added any new hardware or have cables that would interfere with airflow? If so move things around so you have good air flow around the processor. Finally (before we get into the professional portion) you might try adding additional fans to the case, there are fans that will go in a drive bay to help improve air flow.
CAUTION!!!! The following steps should only be taken by a competent professional:
1. Check the heat sink, is there thermal paste leaking out around it (too much paste was used). You will need to remove the heat sink, clean up all thermal paste and then remount the heat sink with a small amount of thermal paste.
2. Remove the heat sink, is the thermal paste dried up? If so, inferior thermal paste was used. Clean up all the old thermal paste with alcohol, replace the heat sink with a small amount of good thermal paste.
Of course if you are running the computer in an 80 degree room, that will affect temperature too.
Hope this helps.
Jul 27, 2011 | ASUS P5LD2-VM Motherboard
Which procesor heatsink and fan can i use for this motherboard
You absolutely must use thermal paste to attach the heat sink to the CPU. If you run your computer without thermal paste, you can ruin your CPU in just a few seconds.
There are many manufacturers of thermal paste on the market currently and each package should have instructions on how to use it. If no instructions are included with the paste, check the manufacturer
Jul 19, 2011 | Computers & Internet
Computers & Internet Logo
151 people viewed this question
Top Spire Computers & Internet Experts
David Payne
David Payne
Are you a Spire Computer and Internet Expert? Answer questions, earn points and help others
