Question about NetGear DG834G Router
I can't access my netgear Modem I need web address
    Problem Solver:
  • 5 Answers
Hi
Do you mean you need the IP address on which you can access the router portal settings?
Try to enter 192.168.1.0, if you cannot still access into the router try to reset the router. You can find a small hole at the back of the router you may use a small pin like paper clip, press the button for 5 seconds.
Let me know here again.
Thanks
Posted on Feb 06, 2010
Testimonial: "Thanks very much This worked perfectly"
  • 115 Answers
HI,
If you need to new web IP address, so you must be reinstall the netgear software. You have change your new Web IP at time of installation. Ok otherwise you contact to your Internet service provider.
Thanks
Posted on Feb 07, 2010
    Guru:
  • 161 Answers
Why dont you try reinstalling it???
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
Authentication failed
A Netgear wireless router attaches multiple devices to your Internet connection, either by ethernet cable or wirelessly.
If you can't connect to the Internet, the problem can be anywhere along the chain of devices and technologies that connect your computer to the Internet.
Knowing how to troubleshoot your Netgear or other wireless router is an essential part of determining where the problem is and fixing it.
Click your "Start" button, and choose "Run."
Type "cmd" in the text box (without quotation marks), and click "OK."
A command prompt will open. Type the following: ipconfig /all. Press your "Enter" key.
A list of numbers and other networking configuration information will display.
Find your network adapter in this list of headers.
If you use your computer wirelessly in many different places, you may have to scroll through a lot of different options to find your adapter.
If you connect to the Internet using a cable, look for a header that begins with "Ethernet adapter Local Area Connection."
If you connect wirelessly, look for a header that begins with "Ethernet adapter Wireless Connection."
You will usually only see an IP address displayed under one header in either category.
Record your IP address and default gateway on a piece of paper or in a text file.
If your IP address is 0.0.0.0 or begins with 169.254, unplug your Netgear router from its power source.
Unplug your cable or DSL modem as well.
Be sure to unplug both devices; turning them off with a power switch may not have the same effect.
Wait 20 seconds before plugging the modem in again.
Wait for the lights on the modem to light up.
Plug in your Netgear wireless router again.
Wait for two minutes. Use "ipconfig /all" again.
You should have a different IP address now.
Ping your default gateway.
At the command prompt, type "ping 192.168.1.1" (substituting your default gateway address for 192.168.1.1).
You should receive four responses, all of which will begin with either "Reply from" or "Request timed out."
If you receive "Request timed out," unplug your Netgear wireless router from the power source for 20 seconds, and plug it in again.
Wait two minutes before using "ping" again.
If you receive "Reply from" responses, check to see if your Internet connection is working again.
Open a Web browser. In the address bar, type "http://192.168.1.1" (substituting your default gateway address for 192.168.1.1).
Press "Enter." If you have password-protected your Netgear router, you will be prompted for a username and password.
The default username for a Netgear router is "admin."
When you have successfully entered the username and password, your Web browser will show you the configuration page for your Netgear wireless router.
If your Web browser never loads a Web page or prompts for a username and password, you're not communicating with your Netgear router.
Double-check the address you typed into your address bar.
If you've typed it correctly and your connection is wireless, either your wireless card has a problem or your Netgear router is not correctly sending a wireless signal.
Make sure your wireless card is enabled (using Windows' built-in Network Connections applet or the third-party software that came with your wireless card).
Make sure your connection settings (SSID, security type, and key or passphrase) are correct for your network.
Look at the lights on your Netgear wireless router.
The wireless indicator light should be green.
If it's orange or not on at all, your router is not sending a wireless signal.
Make sure all the settings on your Netgear configuration page are correct.
Most Internet providers use a dynamic IP address and DNS server addresses.
Some Internet providers require a login, and some do not.
To be sure, refer to the configuration information your Internet provider gave you when your Internet access was installed, or call your Internet provider's technical support number.
Click on "Wireless Settings" on the navigation bar on the left-hand side of the page.
If you were not able to reach the configuration page wirelessly and had to connect to your Netgear router with an ethernet cable, make sure these settings are still as you defined them when setting up your network.
If not, either change the settings to suit you, or change the configuration of your wireless card to match these settings.
Be sure to click the "Apply" button if you make any changes.
Click "Router Status" on the navigation bar on the left-hand side of the page.
Under "Internet Port," check your IP address.
If the address begins with 169.254, you're not communicating with your cable or DSL modem. Unplug your cable or DSL modem from its power source for 20 seconds, and plug it back in. Wait two minutes, and refresh this page.
If your IP address still begins with 169.254, there is a problem either with the cable connecting your Netgear wireless router to your cable or DSL modem, or with the modem itself.
If your IP address is 0.0.0.0, there is a problem with your Internet connection, and you should call your Internet provider's technical support.
Record all your configuration information before trying to reset your Netgear wireless router to the factory defaults.
Resetting may fix your problem, but it will wipe out all your configuration information, and you will have to reconfigure your Netgear router from scratch afterward.
To reset most Netgear routers, use the tip of a pen or an unbent paperclip to press and hold the reset button on the back of the router until the test light blinks.
Release the button, and wait two or three minutes.
Connect to the router's configuration page in a Web browser.
Log in with the default username and password, and configure your router.
You may have to connect to the router with an ethernet cable to perform this initial configuration.
Jul 12, 2013 | NetGear Computers & Internet
How do i set up secured network?
set-secured-wireless-network-netgear-800x800.jpg Set up a Secured Wireless Network on Netgear Photo is inappropriate for this article Submit
A wireless network is comprised of a wireless router, a computer (or other wireless-enabled devices), a high-speed modem, and a subscription to an Internet Service Provider (ISP). Netgear is a popular manufacturer of wireless networking hardware that allows users to set up a secured wireless network. In order to prevent unauthorized users from logging onto your wireless network to gain access the Internet, and in order to protect the data you transmit and receive online, you should change your wireless router's security settings to create a secured wireless network.
1 Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another
2 Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses: http://192.168.1.1; http://www.routerlogin.net; or http://www.routerlogin.com. Press "Enter" or click "Go" in your web browser after you have entered the address.
3 Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
4 Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
5 Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the route
Things You'll Need
* Netgear wireless router
* High-speed Internet service provider (e.g., Comcast, AT&T, Insight)
* Cable/DSL modem
* 2 Ethernet cables
* Computer
* Web browser
* Router address
* Router's username and password
Good Luck : ) ....
Oct 14, 2011 | NetGear WGR614 Wireless Router
I have internet access when I plug in the ethernet cable from the modem, but when I try to access the internet via the router it says 'connected but no internet access'. What is the problem?
I know it is very frustrating if these things do not work. I am sure that the router is not setup properly that is why it is not working. It says connected because you have a good connection from pc to the router. But the connection from your Netgear router to the modem is not working. There is a possible IP conflict between your modem and router. I suggest changing the IP address of your netgear router to 10.10.10.1 . To do this click the link below:
ftp://downloads.netgear.com/files/WNR2000_UM_24FEB09.pdf
Note: This is the manual for your router. Go to LAN TCP/IP Setup Parameters to change the router's IP address.
Apr 03, 2011 | NetGear WNR2000 Wireless Router
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
Connected with limited access, Help!!! I've had some teething troubles with my wireless network but we got there in the end, the latest problem is this... I can connect to my network & have web access...
Let's see if this helps:
  1. Turn off everything. Computers, routers, modem and anything else printers etc.
  2. Turn on your Netgear Router. Let it cycle all the way up.
  3. Now turn on your router ONLY. Let it cycle up.
  4. Now turn on your modem and let it cycle.
  5. Now turn on everything else in any order you want.
Keep power to your router and modem on even when you turn computers off.
Use this procedure if you have a power outage, too.
It's all in the order-it allows your router to assign addresses to your computers .
Dec 10, 2009 | NetGear DG834G Router
I need to change my password in my modem settings but the ip address for the modem will not open up the settings page. my modem is a netgear dg834gu
U try to reset the modem and then again connect it to the computer and with the help of the Net gear Software CD given at the time of purchase of your modem you can re - configure the password and the settings.
Oct 20, 2009 | Computers & Internet
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
73 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
