Question about Protron PLTV3250 32 in. LCD Television
I recently had my DVR unit replaced by Directv, I am not able to program the Directv remote to operate the TV. I tried the three code #'s they supplied; 11320, 11323, 11092 and followed the instructions carefully. Can you suggest another code to try? The remote is DirecTV supplied RC65. The old DirecTV remote works fine but the numbers and letters are mostly worn off and would like to be able to use the new remote.
  • Protron Master
  • 11,800 Answers
 As you can see in its manual    http://www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC65forWeb.pdf
these are indeed the codes. If you have inputted them correctly then your remote doesn't support that tv. The only thing left to do is to do a search in the hope that one of the other codes will work. How to do that is explainde in the manual.
Posted on Aug 09, 2010
Need the codes to program the remote to operate the sound bar
[PDF]Remote User Guide - MyDISH
https://www.mydish.com/filestream.ashx?ID=3037
remote. The standard setting for TV2 operation is UHF. If you wish to use. IR signals ... The on-screen bar ..... a remote-controllable audio receiver or amplifier.
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVLearn how to program your DIRECTV remote control in just a few short steps and ...control up to four devices, such as your TV, HD DVR, DVD player, and audio ...
Is it possible to have DirecTV remote control sound bar volu
Dec 21, 2015 | Televison & Video
How do I setup my dvd to mt tv, i use direct tv
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
I WANT TO USE MY SHARP REMOTE TO OPERATE MY SHARP TVT, DVD AND DIRECTV. I DON'T KNOW HOW TO PROGRAM IT. THE TV MODEL # LC-26DA5U
Go to the Remote control Manufacturers website and get the instructions for the remote control. Then you need the codes for each of the items you are going to program in. You can get some of the Directv functions on universal remotes, but if it's a DIRECTV with DVR then the rewind functions, etc. may not work. Good luck!
Oct 08, 2010 | Sharp Remote Control
Problems programming DVR remote to TV
If your DirecTV remote is in SAT mode and the power button isn't turning the receiver on and off, you will likely need a new remote. There isn't suppose to be any trick to getting the power button on a remote to work. However, only DirecTV tech support can confirm this. I would give them a call right away.
Jul 12, 2009 | Philips Televison & Video
Programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Apr 22, 2009 | Sanyo DP42848 LCD TV
DIRECTV HD DVR REMOTE CODES WILL NOT OPERATE DVR
If you turn off power saver on your tv it should correct the problem...
Mar 02, 2009 | Bose Cinemate Digital Home Theater System...
Direct TV HD Receiver/Recorder codes
Check the Innovage manual for the automatic code search. If it works, you still may not have full control of your HR20. Try to program your Directv remote to operate your components
Jul 07, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Programing Bose Universal remote to DirecTV R15
Check Direct's code info in their info packet.
It should be in there.
Apr 26, 2008 | Bose Cinemate Digital Home Theater System...
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Protron PLTV3250 32 in. LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
