Trying to hook up my wireless router and it wont connect with the interenet..i have time warner cable as my isp...it asks for a usernamne and password that doesn't exist...timer warner said to talk to you
  • 76 Answers
That's a bit cheeky of them.
The user and and password I'm guessing is probably the WEP key usually located on the box itself try locating it on the router should say WEP
other wise they may be looking also for the SNID no. which is also on the box.
Posted on Feb 06, 2010
I have a dynamic ip number which has been blacklisted. This is either a mistake or who knows. I am a private residence who sends average numbers of e-mails. I want to know how to re-set my ip. I
Try ipconfig /release. Then ipconfig /renew from the command prompt without the router connected. Only the ISP modem. The same IP may come back, but you can ask your ISP for assistance.
Mar 26, 2013 | Computers & Internet
Can't connect to internet through router wired or wirelessly Belkin N750 F9K1103 after ISP dropped out for one hour
Unplug the ISP modem completely, power, and cable. There might be a recycle (a quick push) on the modem as well. Some modems have a battery backup and will stay lit, if not connect the power, reboot and then connect the cable. The modem may take a while to fully reload after reconnecting. Then do the same with the router. Only do a quick push. Holding it in will clear custom settings on the router.
You should have green on both the modem and the router now. If not you have this to inform the ISP of your troubleshooting. GL
Jan 30, 2013 | Computers & Internet
How to install netgear wnr834b without cd
It depends on the ISP:
If it's DSL (verizon, att, centurylink, etc)
then you will need dsl login and password credentials. (PPPoE or PPPoA)
some others dont require it (DHCP) so you need to call and ask themt o confirm these.
you might also want to ask them about the ADSL settings: Multiplexng Method, VPI and VCI numbers. This will be very helpful.
For CABLE connections (comcast, time warner, etc)
it should be automatic. but if not try to search for MacSpoofing.
http://kb.netgear.com/app/answers/detail/a_id/1086
Oct 29, 2012 | NetGear RangeMax NEXT WNR834B Wireless...
I have internet with time warner so have linksys router wireless'but when a try to connect to other computer don,t work
First, check to make sure that you can get Internet through a wired connection, if you can't then wireless won't work either. Second, if you can, then try connecting to the wireless without using WEP or any security. You can turn this off by going to 192.168.1.1 in your web browser while wired to the router from your PC and go under wireless security. If you can connect from an unsecured access point then set up a WEP key with a pass-phrase and when you are asked for the pass-phrase from the PC use the the hex key 1 that is generated by the router instead of the pass-phrase. You should have no problem connecting. Thye wizard that comes on the configuration CD will not set up your wireless correctly, you really have to configure the system using the IP.
Oct 01, 2009 | Linksys Wireless-G Broadband Router
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Isp password and name?
Your ISP should give you your username and password, not the router manufacturer. To know how to punch it in your router, please refer to your router user manual.
Mar 27, 2009 | Computers & Internet
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Jan 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Can not connect to the internet in trying to setup the router.
Yes time warner is a cable connection and they dont require a username and pasword. You can set up the router manually by accessing its set up page. By default the router's IP is 192.168.2.1. Make sure to set the wan connection type to dynamic, change the wan mac address or clone your pc's mac. Then save the settings. Check your internet connection.
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
