Question about Forfex FX 789 Hair Trimmer
I have taken the blade off and put it back together and the unit will not trun on. if i loosing the screws the unit will turn on. the screws are just lighty tighten. how tight should the screws be so i don't have to worry about the screws falling out. Please advise. Thanks
    Guru:
  • 194 Answers
Take off all the screws and look to see if there is a wire getting caught and shorting it out. all screws should be snug, not nam handle tight but snug. remember you are only screwing plastic so over tighten and you will break it. You may have a defective switch or one that needs replaceing, but if it runs when the screws are slightly loose I believe it is a wire short.
Posted on Feb 17, 2010
How to disassemble lasko hassock floor fan
I'm assuming you want to open the fan up to give it a thorough cleaning. This is how I got one open. First things first, make sure it's unplugged. No need to risk zapping yourself of accidentally turning it on when your fingers are in range of the fan blade...
Turn the fan upside down. There are four very long Phillips screws concealed by long plastic sleeves that cover the shafts of the screws, with the ***** heads covered by the rubber feet at the bottom of the unit. Pop out the rubber feet, then loosen the screws (there will likely be an alarming snap when they break loose). The two-piece top of the unit will come loose. You can then remove the screws and the plastic sleeves that hide the screws.
Turn the unit right side up and remove the fan blade. The nut holding the blade on is reverse thread, so "lefty loosy, righty tighty" will not apply--turn the nut clockwise to loosen. Remove the nut and lock washer, then pull the blade from underneath the hub (it'll take a bit of force to pop it off.
The wire from the motor to the speed control switch connects the base to the cylindrical center portion of the unit. To separate the center portion from the base, pull the knob off of the shaft of the switch and remove the ***** holding it in place. The switch can then be disconnected from the center piece. I'd put the ***** back into the switch to keep it from disappearing.
The motor can be removed from the base by removing the three screws holding it to the base from underneath, but unless you're looking to replace the motor, you shouldn't need to do this.
Put it back together by reversing the disassembly process.
Jun 16, 2014 | Lasko 2152C Hassock Floor / Box Fan
I have clippers model number HC95WV. I can not get blades back together
Ok place the small metal cutter on top of the large metal comb, place the white plastic piece into the top of the cutter with the protruding bit at the back, place the metal bracket with 4 holes on top first locating the front into the white plastic slot, then place the last metal bracket on top with the raised part to the front, then simply hold it all together and put the screws in form the back!
Hope I got the right blade style!!
Mar 18, 2014 | Conair Health & Beauty
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
Chain came off and it is too long and can't get it back together.
I take it to mean the exact same chain that was on there before now appears to be too long. Obviously, this is a clue. These things don't stretch.
All chain saws will have the chain get loose with use. You should be checking this and make an adjustment before it gets so loose that it comes off which is very dangerous and can cause injury.
When it appears too long, I can think of two things that may be happening.
1. It really is too long and you need to find the adjustment screw near the base of the blade and screw it in (with a long screw driver or the tool that came with the unit when you bought it) which pushes the chain saw blade further out and tightens the chain. Usually, to get the blade back on, I have to tighten the screw and loosen the chain and then make it tight again after everything is together, so experiment with the process of tightening and loosening the screw. (Note, the loosening and tightening assumes that the nuts on the big bolts that hold on the blade have been loosened to allow the blade to slide. Make sure this loosening was done first.) 2. The chain may have slipped of the sprocket gear that drives the chain. If you have not taken the blade off you can't see this gear well and might not notice. Disassemble the blade and put it back together seeing that the chain is properly seated. Don't screw the bolts tight before you adjust the tension in the blade as in my remarks above. Tighten the bolts well, as the final step.
Nov 12, 2010 | Remington Electric Pole Saw
Grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Aug 19, 2008 | Holmes Products HASF1516 Stand (Pedestal)...
How do i clean the iris blades?
This is for Sanyo VPC-HD1, VPC-HD1A black screen problem how to clean auto iris unit.First you have take apart camera : remove 4 screws from right side (in battery compartment) 2 screws from bottom, 2 screws from top (there are different short one is from rear) and last screw from front, now pull left cabinet from top and take appart.Be carefull !!! there is flash capacitor you need to discharge it before doing anything else.You can discharge with  1Kom 5watt resistor . After that remove 1 screw holding speaker, disconnect and remove speaker.Now pull power board PW-1 there is a screw holding lense ring remove that screw, disconnect 2 connectors from lense assy (from ccd just pull, from lense unlock and pull flat cable now you can remove lens assy. Next remove 3 small screws holding heat sink (rear of lens assy) after that remove spacer (black tape from top of lense and another small tape at rear top of lense. Now you can see 7 white screws and 1 black screw remove all of them.Black screw holding iris unit.Now carefully lift zoom motor focus motor 2 sensors nd filter assy and iris unit they came out all together.Next thing main thing you have to open iris unit it is easy to do with sharp blade on the edge of iris unit you will find 2 locks holding  metall casing of iris unit put blade between metal and plastic case and pry to remove metall case. Now you will find iris 2 blades there are different you need to remember wich is wich.Now carefully remove both blades (they might stick to each other because of grease) and place them into isoprophyl alcohol after that put them on to napkin fold napkin so blades are inside and dry them you also need to clean iris unit where blades are going from grease and also clean zoom motor and focus motor shafts to remove grease. Now put everything back together and i hope you can do that. Good luck.
Aug 17, 2008 | Sanyo VPC-HD1 HDV Digital Camcorder
Audiovox SIRPNP2 SIRIUS Radio Receiver
Check your copper pin cylinder on the back of the receiver that goes into the cradle. The metal cylinder surrounding the copper pin can shave off or crack, causing these problems. If you can put your hands on another unit, you can replace this area with the parts unit. Unscrew the two screws holding the unit together and then slowly pry the unit apart, inserting a very thin blade and moving it slowly around the frame. Once inside, you will see screws holding down the area with the copper pins. You can remove this and put it in your receiver.
Aug 15, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
One hissing one shut down
I have two Quadras not sure about the GPS. The only way to clean them properly is to complete the folowing steps. This will eliminate the hissing noises and intermittent shutdowns. Clean the blade unit as normal and leave it out of the unit. Unplug the unit, remove the four phillip screws on the top of the unit where the collector grid slides down. Next remove the four screws holding on to the base of the unit. After this you will see two additional screws also by the base that need to be removed. Look carefully between the grills of the unit and you will see about 12 to fifteen tiny screws that hold the grill together. After these are removed take off the UL label and seprate the grill. You may have to gently pull up on the top where the power switch is located. I have found if you use a lightly dampened scotch brite pad to carefully clean the two wires works best. Clean the wires and pins at the bottom and make sure all is well. Use a microfiber or lint free cloth to gently wipe everthing down and make sure the unit is dry. Put it back together and put the UL sticker back on.
Feb 12, 2008 | Air Purifiers
Purchase the DVD on "How to adjust your trimmers and clipper blades" at www.alexccampbell.com
Jan 15, 2008 | Andis Outliner II Hair Trimmer
GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
Jan 08, 2008 | Refrigerators
Forfex FX 789 Hair Trimmer Logo
87 people viewed this question
Top Forfex Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
