Question about D-Link AirPlus DI-524 Wireless Router
Acess problem i cant seem to access my routers home page to change my password since i installed windows seven ultimate any ideas
  • 76 Answers
Go to start and type run then type in cmd then type in the cmd box ipconfig and then look for your default gateway number.
type that number in your web browsers address line.
will look something like this but your number will be different.
111.111.1.111
Posted on Feb 06, 2010
Why cant i access wireless in my home or download
Can you verify if other devices can have access to the internet in your home? If you can access wifi connection elsewhere, then most likely your wireless router is not configured. You didn't specify if it ever has been. Router needs to receive the internet signal from outside the house and make it available through radio. Depending on the make and model of your router, you would need a hard-wire connection between your PC and the router. Then you need to configure it, assign a wifi name, security type and password for it. Write it down on a sticky label and stick it under the router because eventually this info gets forgotten.
Aug 27, 2014 | Microsoft Windows Vista Ultimate Edition
Why i cant acess my router page of my dlink seconday router which is connected to cisco router before i could acess my dlink router page but after some days cant acess my dlink router page yet i can acess...
Try to reset the router and how can't u access it like pls could u explain in more detail is it to with tha password or what pls could u send some picks if possible
Jul 03, 2014 | D-Link DIR-600 Router
Wep code
This code is from your router and not the motherboard. Go to the website of your router manufacturer, and get the install program from thier site, or at least the directions.
The security code(WEP)is a wireless acess code.
Here are the highlights of what should be set:
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Feb 04, 2011 | Computers & Internet
Trying to connect my mobile to my wirelesss Netgear,keeps asking for wep
You have set your wireless connection as Secured Wireless Network when you configured your wireless Modem/Router, so you need the "Network Keys" (ie the set password) to access to your wireless network. That is why your wireless cxonnection is asking for the "WEP KEYS" in order to connect to your Wireless Acess Point.
You can read your modem/router manual how to access to your router to see what password you have set.
or
Refer to the link, here
Hope it helps.
Nov 17, 2010 | Microsoft Windows Vista Ultimate Edition
Forgot password to log on for my wireless connection trying to add my Wii and now cant even get my laptop back online
You can check the passphrase when you access the router page:
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • If the Wireless Security Key uses the default, the Passphrase is the 10 digits located underneath the router under the S/N.
Thanks for using Fixya.
May 13, 2010 | Computers & Internet
Installation
U can configure ur wireless router with WEP security and provide a security password, so that the person unkown to this password can't use the internet
Apr 24, 2010 | NetGear DG834G Router
Wrt54gl acess point,Hi can u help me about some technical problem my acess point are stoped when is been storm, he dosen dedicated a wan enter some idea??
Try the instructions at this Tips page to reset the router to factory defaults. Once that's done, you should be able to connect to it on the wired LAN by pointing a browser to http://192.16.1.245/
I've also written a tips page about the default address, username and password for this access point.
Sep 23, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Need to re-configure wireless router and I am not very technical.
first connect your wi fi router to your computer with ethernet port.
u can acess router with following link
http://192.168.0.1
or http://192.168.1.1
type username and password "admin"
or password remain blank
May 07, 2009 | ParkerVision SIGNALMAX WR1500...
Dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
Mar 24, 2009 | Dynex DX-E401 Router
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
