Question about Samsung LN-R409D 40 in. LCD Television
When i start up my computer, it takes 15 minutes before he his realy starting up. He also makes a lot of click clack noises. Once he is started up everthing looks fine
  • 201 Answers
That is a common problem with Samsung some capacitors on the power supply are bad. (Look for caps that are rounded on the top they are supposed to be flat, most of the others will be) You can replace the bad caps for just a few $$$ the value of the caps are written on the side like 1000 mf 10v etc.. you can find them online just about anywhere. If you need o pay a repairman see if they will do the caps, many will replace the whole board and easily become a $300-400 dollar repair.
This link Samsung Lawsuit is to an article that has info on a law firm buildin a case to go after Samsung or this very issue. Good luck!
Posted on Feb 06, 2010
My car started making noises when accelerating , like a tapping noise .Went to start it there was a really loud clacking noise coming from engine .
The first sound you describe is detonation or spark knock and is caused by a lot of things.. The second one is bad news. Could be a rod that is failing.
Jan 30, 2016 | Cars & Trucks
1998 rear brakes make a noise when backing
Noise after replacing rear brake shoes and drums...help! - Toyota ...
www.toyotanation.com/.../328271-noise-after-replacing-rear-brake-shoe...
Jan 19, 2010 - 15 posts - ‎9 authors Check to make sure the new drums dont have a longer/thicker drum face that is scraping the back plate. ... 1998 Mazda 626 FS-DE/CD4-E .... I experienced rear shoebrake clicking/clacking with an older Saturn. ... plate and to be banged back against the plate causing the clicking or clacking noise. screeching noise from rotors + brakepads after ...
Nov 20, 2009
'95 Right Rear Brakes makin' a "clicking" noise when ...
Jan 6, 2008
Rear Brake Noise
Oct 30, 2005
More results from www.toyotanation.com
Nov 08, 2015 | 1998 Toyota Camry
I drove through 12-15 inches of water and now my drive train is making clicking and clacking noises when I let off of the gas driving 20-40 miles per hour, before this it made metal squeals my neighbor...
It sounds like you need to replace some U joints. When U joints start making noise it is too late for grease to fix the problem, the damage is already done. To be sure get under the truck and move the driveshaft at each joint. Try to move it up and down and from side to side. If there is any movement in the driveshaft and none in the yoke, the joint is bad. You should also try turning it to check for movement. Do this with each joint because it is quite possible that move than one joint is bad.
Don't put off fixing this because you run a real danger of having one of those U joints failing and the driveshaft falling. When you order new ones make sure they come with grease fittings. Once a month 10 minutes with a grease gun will save you a lot of money and extra work over the life of the truck. Hope this helps.
Apr 21, 2011 | 2005 GMC Canyon
2004 Dodge Dakota 3.7L V6, manual. Below freezing out. Started up my truck it started making lifter noises upon start-up. I thought it was cold, so I let it idle for 10-15 minutes. As it was idling,...
P0300 Random/Multiple Cylinder Misfire Detected
P0304 Cylinder 4 Misfire Detected
If a cylinder is not firing it could make that noise. Check/replace your plug wires use dielectric grease in the boot connections. Could be a bad plug as well but I would guess a bad plug wire...
Nov 27, 2010 | 2004 Dodge Dakota
What will cause a Clacking/Clicking noise coming
It maybe a loose heatsheild on the manifold, converter, or underbody heatsheild.
Jun 03, 2010 | 2000 Jeep Grand Cherokee
The harddisk makes noise and doesnt respond the Mac computer
Let the computer run for 15 minutes then switch it off, wait a minute, and then start it up again. If there is a repeated clicking sound then it is more than likely that your hard drive is broken and you will need to take it to a qualified technician to look at it.
Apr 26, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
1995 toyota tercel made a clacking sound and stalled
SORRY but I need a lot more information than what you have given me.
Where did the clanking come from under the car /from the engine/from gear box/back or front wheels/etc, and what is it doing now when wont start and just clicks ,,do the dash lights go out ,,
Turn on head lights and then turn the key to start (do the lights go outand clicking still there)
If so it sounds like the problem is in the converter
So let me know ASAP Ron
Oct 09, 2009 | 1995 Toyota Tercel
Loud clack on shutdown
Unfortunately it is probably the Sprag Clutch. My '95 did that for a while. Then it got worse and started making the noise during starting.
Nov 10, 2008 | 2003 Triumph Thunderbird Sport
98 f150 4.2 110.000 miles went to start up engine started clacking and smoking out exhaust
the intakes go bad on these engines....... they leak coolant in the cylinders and cause a hydro lock that causes the rods to bend making the piston skirt hit the crank......" clicking noise" theres a law suit in progress for this issue......... you can find info on the internet
Oct 15, 2008 | 1998 Ford F150 Regular Cab
Samsung LN-R409D 40 in. LCD Television Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
