Question about Buck Kidz Kargo Discovera Double Jogger Stroller
I've been given a Kidz Kargo double buggy (3 wheeler style) the back wheels can be detached. one of the them is missing the round dented bracket type which helps clipping the wheel onto the axle.
I have had this stoller for two years and these locking clips have all gone missing. The manuf. at www.kidzkargo.net apperars to be OOB. I took it to a pro bike shop and they said if the manuf does not have it, then holes will have to be drilled into the axels and pins inserted. This is a BAD stroller. Good Luck
Posted on Mar 08, 2010
Where can i get instruction for a phil & teds e3 double pushchair ?
Posted on May 05, 2011
How do I tighten the wheel assembly on a 2005-07 Mountain Buggy Urban Jungle Double stroller?
This is a press or pound on type nut usually a one time use! But if you are carefull you can unscrew with a pair of plyers by turning both ways but pulling hard on them! Once you get it off you can put washers on the axle to take up the play. Then before you put the press nut back on make sure you didn't bend up the little pieces of the metal. They should be bairly slanting to the inside of the nut. If they are slanting to the out side bend them in gently. them tap the nut back on!
Mar 18, 2015 | Mountain Buggy Baby Gear
Tip
How to Identify the Type of Bottom Bracket on a Schwinn IC Pro
Video about Identifying the Bottom Bracket on a Schwinn IC Pro Bike
  • This video will help easily determine what kind of bottom bracket you need for your Schwinn IC Pro
  • You see in the video there are four available
    • The first one showed is the OEM style bottom bracket, on both ends it is a square tapered shaft bottom bracket
    • We offer a Sportsmith bottom bracket kit including the crank arms and crank bolts
      • This is also a square tapered shaft bottom bracket
    • We also offer two ISIS style bottom brackets
      • One is a 1 7/8" diameter
      • The other is 1 3/8" diameter
      • As you can see in the video these both have a round splined shaft
      • To identify which ISIS bottom bracket you need you will want to remove the crank arm and measure the hole in the frame that the bottom bracket mounts into
  • You will have to determine if you need a round splined shaft or a square tapered shaft
  • If you do need the round splined shaft you will have to know if you need the 1 3/8" or the 1 7/8" diameter bottom bracket
  • Knowing these things can reduce the frustration of buying the wrong parts and shorten down time greatly
How to Identify the Type of Bottom Bracket on Schwinn IC Pro
on Feb 25, 2015 | Schwinn Ic Pro Indoor Cycle
The bar that attaches to the pedal needs some kind of pin to put the pedal back on.
I think I know what you are asking, but you haven't given me much to go on. Here are the names of the parts going from pedal to pedal -- pedal, crank arm, bottom bracket arbor, crank arm, pedal. Are you asking about attaching the crank arm to the bottom bracket arbor? And if so, are you missing the tapered pin that older bikes used to make this attachment? If so, the crank arm has 3 holes in it - one for the pedal, one for the bottom bracket arbor, one for the tapered pin. And your bottom bracket arbor will not have a square end, but will have a round end with a flat spot about 3/8 inches square. If you are missing this pin, then take the bike to a bike shop. It's a very inexpensive part, but might be hard to find the right size- or might require a little modification to fit. good luck Al K
Oct 15, 2010 | Cycling
ONE OF THE WHEEL RELEASE CATCHES IN THE END END CAP HAS BROKEN. (kidz kargo pram)
More than likely they use the same type that a bicycle does, (there are only so many manufacturers, so they sometimes use bike ones). Go to a local bike shop with your wheel and let them match it up for you. Without seeing it, I don't know for sure. Good luck
Oct 07, 2010 | Cycling
I have a Rascal 245 Mobility Scooter which is 3 wheeled. How can I make it more stable than the little caster wheelers they use?
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Sep 24, 2010 | Golden Technologies Golden CompanioN II -...
Left back wheel comes off clean - kidz kargo
Did you get an answer to this question because the same thing happened to me, all i need is a new pin!
Mar 15, 2010 | Delta Enterprise Baby Gear
Need a spare wheel for a combination mamas and papas pram
i have a 3 wheeler fisher price buggy but the back wheel clip is nackerd where can i get new wheel
Mar 20, 2009 | Back to Basics Baby Gear
Tandem pushchair spare parts
HI there. Try contacting Kidz Kargo customer support by email at info@kidzkargo.co.uk They will deifnately be able to tell you whether or not a replacement part is available for this item! I hope this is helpful! If so, please leave me a great rating! Good luck!
Sep 04, 2008 | Baby Gear
Buck Kidz Kargo Discovera Double Jogger Stroller Logo
834 people viewed this question
Top Buck Baby Gear Experts
Dorel UK
Dorel UK
Bill Boyd
The Audio Lab
Are you a Buck Baby Gear Expert? Answer questions, earn points and help others
