Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Brother MFC-665CW I recieve 2 codes on printer screen. Unable to print 30 & unable to print 50, Printer is 5 months old. Can anyone help.
  • 7 more comments
  • Joseph Carrig Feb 22, 2008
    Mix-it-up, I must say thank you very much for your help. Brother said the encoder was bad and they would pay for the part but not
    labor. $75 bucks! If it helps any, my MFC-665CW, the clear plastic strip on top of the head was out of slot. You showed me the Light. Thank you, Joe
  • vibhu40 Apr 20, 2008
    error on my printer is unable to print 30 any solutions
  • L Shippey May 22, 2008
    My printer jammed and I removed the paper and now I keep getting unable to print 30 and also unable to print 50 codes. Since this problem occured my printer is dispalying offline as well when I view it on my system.Please can you tell me how to fix this, the printer is 5 months old.
    Lisa
  • lucasr956 Jul 17, 2008
  • Anonymous Oct 14, 2008
    My printer show Unable to print 30 & 50
  • catsndogs Mar 02, 2009
    Exact same problem; had a paper jam, removed all of the paper, now continue to receive unable to print 30 and 50 error messages. User's guide is worthless. Is the only solution to call Brother and ask for new Encoder (what ever that is) for which they will not pay labor to have it installed???
  • Raisel Apr 07, 2009
    I recieve 2 codes on printer screen. Unable to print 30 & unable to print 50. Can anyone help?
  • tino c Apr 16, 2009
  • Anonymous Mar 14, 2014
    Unable to print ED on brother 3075cw printer. Thanks
  • 3 Answers
Hi
Here's how I got rid of errors#50 and #51 on the Brother MFC-665CW, MFC440CN and like.
Open the 2 top-covers and locate the printer hole, a large horizontal hole near the back of the printer. The printer head is usually on the right and the cleaning pad, on the left. Locate them with a flash light.
For error #51 (Inkpad full): take some Scott Towel and gently press on the cleaning pad. Be ready to fill several Scott Towel sheets. Wear some gloves and/or have some "Clorex"/"Hertel plus" nearby to clean your hands.
For all errors (50 and 51), unplug printer and manually move the head to the left. You may have to play with an horizontal bar with a gear at the right, near the printer head. The printer head get stuck in that gear and it pops error #50, but it can be unstuck gently by hands. close covers and power-up. Expect 3-5min for the printer to clean-up. First sheets may not have all colors.
Posted on Jul 17, 2012
  • 832 Answers
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Unable to print 30 and 50...what do i do?
what do i do...unable to print 30 and where is the encoder at?
Sep 03, 2009 | Brother Multi-Function Center MFC-665CW...
Unable to print 30 or 50
the encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
Jun 25, 2009 | Brother Multi-Function Center MFC-665CW...
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
I have a Brother MFC-665CW printer/fax machine. It jammed with paper and once I had cleaned it up the screen now reads, Unable to print 30. I can't do anything. Does anyone know how I can fix it please?...
Normal 0 In most cases it works. Worth a try.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Dec 15, 2008 | Brother Multi-Function Center MFC-665CW...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
1,507 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
