Question about Philips 55PL9223 55" Rear Projection HDTV-Ready Television
I need to change the language on my Philips tv. I dont know which one it is but it says on the back UVSH and SLC4.3EAA
Need help for Philips tv
Get into its SDM mode. There is option to change the language. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 11, 2013 | Philips Televison & Video
HI all i have 2 question lol - first the language on my tv hannspree 40 inch has changed to a language i dont know i need to change it back to english and the second question is how do i get the stup
The language will be indicated in the menu--if another language other than English--use the free Google "Babel Fish" to translate words to english and then in the menu make the correction back----menu button on remote or set should take you there.
Apr 29, 2012 | Hannspree (K206-10U1-005) Television
Philips uvsh 21pt1557/01
Usually in this model and case a short either in the power supply or the High voltage circuit.
Apr 18, 2012 | Televison & Video
How to change language to english when i turn on wrong language is shown and i dont know how to change it when i purchased it i went through introducion on computer but must have enterd wrong language and...
There is a user manual here;
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1MXX04K/37&scy=US&slg=en
Try it this way first;
Use up and down to move >II to select
From the main menu Settings is 4 down, select
In Settings, Language is 3 down, select
English, the default, is the first item, select
Jan 30, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
I cant find the local antena connection on Philips 30 Inch UVSH TV
theres only one antenna connection on this type of set, you will use a coaxial connector and then depending what type of indoor/outdoor antenna,satellite,cable you opt to receive the signal from,then you must get into the tv sets "menu" and change the tuner to whatever it calls for
Sep 15, 2009 | Televison & Video
Please does anyone know how to manually tune in a phillips uvsh TV Model: 25pt4521/07. I don`t have original remote but universal one operates fine (except for tuning maybe !). thanks ****.
your gonna need the ORIGINAL REMOTE control BECAUSE it has those other special options design for this unit besides the basic operations . heres a link where you can purchase a new one , hope its helpful. http://www.replacement-remotes.co.uk/products/Philips-25PT4521-07.shtml
Apr 22, 2008 | Televison & Video
Child lock
Do I need a remote or can it be unlocked manually? Yes press 0000
Apr 20, 2008 | Televison & Video
Philips 55PL9223 55" Rear Projection HDTV-Ready Television Logo
203 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
