Question about Maytag Dryers
Maytag lsg 7804 aae dryer does not heat, clock control dial works, igniter comes on, buner tube does not light, it was working! gas tanks run empty, replaced tank an bled the line several times, all other appliances work ?????? HELP
3 Suggested Answers
  • 659 Answers
SOURCE: Maytag LDG733$AAE gas dryer (propane) no longer
You may want to check the thermal switch to make sure it isn't bad or tripped. Check the standard things like, is the gas valve being told to come on by the controls. If it is then is the gas valve opening? These are things you will have to check with a volt meter if you have one.
Posted on Apr 09, 2009
SOURCE: how old is this machine
I have the lat 9334 aae washer and still have my sales slip from 12/20/1994. Still runs like a top! Hope that helps!
Posted on Oct 23, 2010
Maytag gas dryer lsg 7800 just replaced gas valve dryer now heats but timer does not advance or shut off
Ok that machine was built back in 89, good chance the timer is out. If you really like that machine I would get as many replacement parts I could find for it. They are better machines than the ones they are selling on today's market.
Apr 18, 2014 | Dryers
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
Maytag LSG 7806 Electric Dryer doesn't heat up how can I get a wiring diagram
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 30, 2010 | Maytag LSG7806A Front Load Stacked Washer...
How old is this machine
Nov 24, 2009 | Maytag Dryers
Maytag LDG733$AAE gas dryer (propane) no longer heats.  Additional # A0256402KB.  Any suggestions?  Age of dryer?
Apr 09, 2009 | Dryers
I bought a used maytag lsg 9904 does not seem to be getting power
You might want to check the main fuse in the top panel cheers
Mar 24, 2009 | Washing Machines
Maytag washer filled with water then stopped working.
check your belts there are two of them one for the pump and the other the transmission
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
I have a Maytag washer MOD # LAT 2300 AAE
If the machine does not start.
Make sure the circuit breakers or fuses are functional in the main electrical panel.
Try to turn them OFF and ON again.
You might need to check the thermal or non thermal fuses inside your washer.
If all appears in working order, you might have a burnt motor if no noise comes from it when you pull out the knob.
Apr 07, 2008 | Washing Machines
Maytag LSG 7806
Will try, my email: premmathew@rediffmail.com
Apr 02, 2007 | Maytag LSG7806A Front Load Stacked Washer...
Dryers Logo
100 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
