Question about Dell Inspiron 6400 Notebook
Display needs replacing
The display needs replacing. I have the replacement display that fits inside the frame. How can i do this myself? I've done it on my Latitude D430, but the Inspiron 6400 is different. Can anyone help?
  • Dell Master
  • 2,404 Answers
Take off the round rubbers that are covering the screws. There should be 4 screws on top and 4 screws on the bottom. There might be stuff covering the screws, if so take the covers off.
Once you have all 8 of the screws exposed, unscrew all the screws from the lcd bezel. After you get all the screws off then you might need a flathead screwdriver to get the lcd bezel off, put it in a area of the screen and twist the screwdriver to get the bezel to unsnap, you may have to do this in a few areas. Then you should be able to get the bezel off.
Once you do this there will be two screws on the left bottom and two screws on the right bottom. Take off those screws and it will release the lcd back cover. Now at this point you'll be able to get to the screws that are holding the lcd in place on the left hand side and the right hand side. Take off those screws and the screen will become loose, take off the lcd cable from the back of the lcd and you'll now be able to completely remove the lcd.
Once you do that put the new lcd in and put the screws back on the left and right hand side of the lcd. Then connect the lcd cable to the lcd. At this point put the lcd back cover on and put back the 4 screws that are holding it in. Now put on the front lcd bezel and put all 8 of the screws back into it.
At this point turn on the laptop and you should get video.
Posted on Feb 06, 2010
I already change the adapter but same result.
If your adapter is ok, the most possible problem is that your laptop dc power jack. So you may check it out. Either replace it or get it repaired.
Replacement Dell Latitude D430 AC Adapter 90Watt 19.5V 4.62A
Feb 24, 2013 | Dell Latitude D430 AC Adapter 65 Watt...
Sound card problems with Sigmatel High Definition Audio codec in Dell Latitude D430
This sounds like it may be a bad connection to the speaker or the speaker is failing. Either way you will need to open the case to get to the speaker and check that there is no issue with the motherboard connection. As the motherboard gets hot it expands and then contracts again when the system cools. This can cause issues with solder joints. Otherwise, you'll probably need to fit a new speaker.
Mar 28, 2012 | Dell Latitude D430 Notebook
I need to reset my bios or find the administators password for a Dell Latitude D430 Laptop with a service tag: FRGW0G1
You can purchase one From eBay, you need the extension, whether it is 595B or something like that.
Jan 15, 2011 | Dell Latitude D430 Notebook
My D430 laptop has a 32GB solid state hard drive which is nearly full and needs to be upgraded. It must have a solid state drive made for the D430 but I can't seem to find a larger solid state replacement...
I found one for £202.00 a 64GB one.. what an obscene amount of money!
http://www.bzsale.com/product/NEW-64GB-SSD-1-8-ZIF-MLC-for-DELL-D420-D430-OQO-umpc_P7896-GBP.html
I'd suggest you invested in a portable hard drive for your data at a tenth the price you could get a 100GB drive
Dec 31, 2010 | Dell Latitude D430 Notebook
I want to reset BIOS password for Dell Latitude D430 laptop. hash code is #9s6vfbx
To reset the BIOS read the information from this link.
In case of your Dell Latitude laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 26, 2010 | Dell Latitude D430 Notebook
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
Jan 19, 2010 | Dell Latitude D430 Notebook
My D430 stopped recognizing my LAN card. This
Changing your CMOS battery will reset your BIOS, you just need to configure your bios to enable Local Area Network connections, to do this go to CMOS setup and find network setup utility and enable the LAN, hope this helps...
Oct 21, 2009 | Dell Latitude D420 D430 8x DVD+RW / CDRW...
My dell latitude d430 dvd drive is not working itis not connecting to notebook i am using windows xp
Try reseating the drive. If this doesn't work it maybe faulty try a replacement drive.
Sep 27, 2009 | Dell Latitude D430 Notebook
Dell Inspiron 6400 Notebook Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
