Question about LG Studioworks 563N 15" CRT Monitor
Power is on(green) but no picture or (no signal)
When i turn on the monitor without the signal cable connected the green LED lights up but the screen doesnt shows the no signal message or the LED doesnt goes amber after a while. Also i am able to hear some sounds like something is being switched on/off inside the monitor. this switching sound is random and most probably less than 4. i am using lg studioworks 563n crt monitor and is 3-4 yrs old.
The sound from relay due to failure start
this failure caused by short circut in horizontal sweep transistor beside the high voltage transformer
Posted on Nov 02, 2011
The problem is your power supply section STRG8644D regulator no parts available in the market only LG service center have it
Posted on Mar 01, 2008
  • 40 Answers
May be the problem with the output transistor
Posted on Feb 26, 2008
Whats the problem with no picture on the monitor but the cpu is working
Can you observe any LED lights on the monitor panel when you try to turn it on. If no then check your power cables. If you can see the LED lights but screen does not show try to unplug the VGA/HDMI cable and clean it by blowing air through the plug and then reconnect it. Also try to turn on the monitor without connecting it to the monitor as this will verify if the monitor is OK because if it is it should display a message to check the input signal or no input signal is detected. If it does and you are still not having a display then the problem is probably in your CPU and more specifically in the VGA card.
Sep 23, 2013 | Samsung Computers & Internet
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Neovo x17a monitor
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
Aug 15, 2007 | Neovo AG 17" LCD Monitor
LG Studioworks 563N 15" CRT Monitor Logo
296 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
