Question about Sony NW-A1000 MP3 Player
Is it possible to open up the NWA-1000? e.g. to replace the battery?
  • 80 Answers
Yeah, of course it is possible, but the only thing is that you've got to be very careful. Usually on mp3 players, the back is usually where the battery is. So I suggest you use something like a flat screw driver to gently open the clips.
Posted on Feb 06, 2010
Have several Tripp Lite Omniplus 1000LCD UPS battery backups that are no longer working. They are several years old. I assume that these units need new batteries. Where do I get battery replacements,...
A little research on the internet will answer your questions about battery replacements and cost. There are numerous sites selling batteries for your particular unit. Do a Google search on the battery type and see what you get. EBay is another possible source for batteries once you determine which size and what ratings you need for your replacements. The best way of determining how to replace the batteries is to open the UPS's case and carefully record how you remove the old batteries and then install the new ones in reverse order. You will have to open the UPS up to get at the batteries to determine type and specs so removal and re-installation should be easy from there.
Apr 30, 2011 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
I need to know how to change the battery. Can you send a manuel.
Printed instructions for battery replacement are not provided by the manufacturer.
You will find batteries for model ES-1000 at shaveroutlet.com. See link below (you will need 2 batteries)
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
To open up the shaver, gently pry off the rubberized grip on the front with a small flat screwdriver or similar. This will reveal 2 screws at the bottom. Remove the screws and the flat plate under the cutters that clips on there. You can then gently pry apart the two halves.
You can then access the batteries, remove the old ones and solder the new ones in place
Oct 18, 2010 | Remington ES-1000 Electric Shaver
The ups wont work when its on battery or on electricity and nothing happens when i press the (on) button it remains off
These units, while hot swappable, will NOT start with dead batteries connected.
You will have to replace the batteries to confirm if the unit is still usable. Sealed Lead Acid Batteries do have a shelf life when a charge is not applied and will fail after several months of sitting around.
If your unit was working fine before it was put in storage, I definitely would consider just replacing the batteries. It is possible that the batteries are connected loosely, you can try opening the unit up to double check all the connections but if it has been sitting for more than a couple months, I would definitely consider the batteries dead.
Apr 13, 2010 | Tripp Lite Lite OmniSmart 1000 PNP...
It is possible to attach the 120 AH battery with APC 1000 va UPS
YES IT IS POSSIBLE TO CONNECT A LARGER BATTER TO THE APC UPS. IT WILL ONLY NEED MORE TIME TO CHARGE THE BATTERY.
Apr 10, 2010 | APC Smart-UPS 1000VA UPS System
BATTERY CHANGE FOR NWA 3000
The little disc on the back needs to be taken off. Try slding a knife under it. Then the battery is just a simple connection. Should be simple once the back cover is off
Oct 01, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Screen freezing at start up
Does it make a clicking noise when you switch it on, then your hard drive is broken and needs to be replaced.
Jul 29, 2008 | Sony NW-A1000 MP3 Player
LEXMARK WHEELWRITER 1000
Sounds like a keyboard, if you send it to us we can repair it for about 125.00.
bizmach@earthlink.net
hope we can help you
DickyO
Mar 04, 2008 | Lexmark Wheelwriter 1000 Typewriter
Nwa-3000 music plays but no screen shows up!!!!
Reset
Update Firmware
Double-check with Sony
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
If fails, then the player is officially dead
Feb 23, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Sony NW-A1000 MP3 Player Logo
283 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
