PC can not start. Hi, I've got a PC which last times can't swich on. After pressing power button hundreds of times, finally boot up and working fine, but after I switch off can not start up again (not only dont boot up, but not even power up at all). The power button sounds fine, PSU? or try something else? Cheers
  • mctros Feb 07, 2010
    Thank you
  • 2,404 Answers
Try a different power supply and make sure only the connectors to the motherboard are connected. Do it this way so we rule out whether a piece of hardware is causing the problem. Try turning it on a couple of times, if you can get it to turn on consistently with no problems and to turn off with no problems then that means the original power supply is bad.
If you do this and the system intermittently still won't turn on properly or turn off, then you know the original power supply is good.
If it turns out that the original power supply is still good then look at the motherboard, see if there are any capacitors that have a puffy silver top to them. A good capacitor will have a flat silver top on them. If you find any capacitors that have a puffy silver top on them, then that means they need to be replaced with ones of the same UF rating and at least the same voltage or higher.
If you don't find any puffy capacitors then try unseating and reseating the memory one stick at a time in each slot one at a time. If that doesn't do it then unseat and reseat the CPU.
You'll know the motherboard is the issue if you still can't get the machine to turn on properly after doing these steps.
Posted on Feb 06, 2010
Reboot Toshiba laptop
Step One: Remove power (either pull the battery or press and hold the power button)
Step Two: Add power (either put the battery back in or press the power button just once)
Step Three: Press F2, F10, and F12 buttons repeatedly one at a time until boot menu screen displays.
Step Four: Navigate to boot options
Step Five: Boot in Safe Mode
Step Six: Once computer has booted properly restart computer.
Step Seven: (If asked, select launch last known good configuration)
If this doesn't work please send more information.
Image of boot menu screen attached
May 04, 2016 | Toshiba Computers & Internet
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
Hi, I have a sony vaio vgn-fw265d and the last time I used it I put it to sleep but didn't connect it to any power source so the battery drained out. When I tried turning it back on, the light switched on...
Remove the battery and try to start it up with the AC power. If it's not working, after you try to boot up and the lights are on, press the power button for several seconds (10-15) and it should go off. Press the power button again and it should start.
May 02, 2011 | Sony VAIO Notebook
Hi, i have a dell inspiron 6400 and since yesterday when i turned it off it re-started itself on and enter directly in to the media direct express automatically.\r\ni´ve been starting it and pushing...
Hello.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this helps.
Oct 21, 2010 | Dell Inspiron 6400 Notebook
Hi, I've got a PC which last time can't swich on. After pressing power button hundreds of times, finally boot up and working fine, but after I switch off can not start up again. The power button sounds...
do you know how to turn on your pc just shorting inside the motherboard???
try that if it works.. it means your button is the problem if not..
your power supply is the problem..
hope it's a help..
rate this plz..
Feb 06, 2010 | Office Equipment & Supplies
My Acer extensa4420-5963 has been acting funky for the last three/four days. Started out my date and time went haywire. Clock kept losing time as soon as laptop was turned off and reverted to battery. Then...
First of all the RTC (real time clock, BIOS/CMOS) battery has run out. This means the computer cannot keep the date and time when its turned off and disconnected from the mains. You will need to take the laptop to a reputable PC repair store and have them fit you a new CMOS battery.
As for the power on problem, this well could relate to the CMOS battery being drained but also could be a number of different reasons why it won't power on properly.
In my experience laptops that have problems powering on is either to do with the DC adapter on the laptop that has a dry solder point or the power board is failing.
Either way i would take the computer to be looked at.
Regards.
Jan 25, 2010 | Acer Computers & Internet
Compaq Presario R4000 Notebook won't boot
Seem to be a problem with your power switch doing malfunction or bad motherboard connector or your computer has been setting at hibernate mode. Check those settings going to >> Start >> Control Panel >> Power Options..........Set your droplist to "never: and also UNCHECK the hibernate mode.
Another tip, take out the battery, and see what happen (only connected with AC)
Oct 13, 2008 | Compaq Presario R3000 Notebook
NEC Versa s970
when the bluetooth and wlan light are off press the wireless button three times and wait a sec and it will work. thats what nec told me
Apr 16, 2008 | NEC Versa LX Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
