Upgrade Baystat 239 to a Honeywell RTH7600D controller
I have an air handler (American Standard TWH030B14,0A,FA) mounted in the attic connected to a heat pump (Trane XE1000) mounted outside controlled by a thermostat (Trane Baystat 239) mounted in the family room. I want to upgrade the Trane Baystat thermostat controller to a digital controller. The controller has the following terminals with corresponding wire color in a counter-clockwise pattern:
X2 = Black
O = Orange
G = Green
Y = Yellow
T = Brown
R = Red
W = White
U = n/a
F = n/a
B = Blue
I want to use a Honeywell RTH7600D touch screen to replace the Trane Baystat 239. Can you advise the correct terminal placement from the Baystat to the Honeywell controller?
  • Dennis Boxerman May 11, 2010
    On comercial Trane units, you have to add a converter board as their controls do not directly hook up to a standard control. I would suggest calling Honeywell. They have been very helpful in the past and they make the unit you are trying to adapt. Trane has their own,unique control system. Good luck.
    Guru:
  • 415 Answers
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Posted on Feb 07, 2010
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
Feb 28, 2015 | American Standard Heating & Cooling
Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
Jul 13, 2017 | Heating & Cooling
Replace air conditioner transformer
it would be in air-handler in attic. check fuse at control board usually 3 amp that protects transformer.
Nov 22, 2013 | American Standard Heating & Cooling
This is a Unico AIR HANDLER in a residential application with heat / cool unit in the attic. With system off (not calling for cool) and fan in auto mode, the blower fan is on high speed only constantly....
Sounds like a sticking relay. You can check the stat simply by remove the faceplate. If fan still runs with tstat cover off its not the stat. Not sure is your blower has a separate relay or if relay is mounted on control board. This can be bypassed with a new relay if you are willing. Good luck!!
Mar 26, 2017 | Heating & Cooling
Honeywell RTH6300B to replace Trane Baystat 239
Sad to say but you have bought an non compatible thermostat, what you need is a thermostat that has "Heat Pump" somewhere on the package, Honeywell makes those also in the same models, sometimes they can be tricky if your not looking. It should also say 2heat, 1cool too. Hope this helps and good luck!
May 23, 2010 | Honeywell Focus 6300B 5-2 Days...
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Does my Heil air handler have a air filter or just coils??
The Air filter should be located under a grid in the ceiling somewhere in the house. That is where the air in taken and returned after it passes thru the air handler in the attic. There has to be an access to the attic in order to service the air handler if needed. That is Code. Your system, I presume, is a "split system" with the condensing unit outside and he air handler in the attic...
May 30, 2009 | Heating & Cooling
Need wiring help for replacing trane model baystat 239 with a honeywell th8321u thermostat
I am not sure of what help you need on it but here are the most common wiring on a stat
W= heat
C=Common (24V)
R=Hot (24V)
G= Fan
RC=Hot (24v for Cooling)
RH= Hot (24v for Heat)
O= Reversing Valve (Heat Pumps Only)
Hope this helps
May 11, 2008 | Heating & Cooling
Heating & Cooling Logo
1,904 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
