Question about Yamaha P3500S Amplifier
My yahama P3500s Amplifier left channel dead and clipping light stays on both speakers works ok in right channel.
    Sergeant:
  • 226 Answers
Hi, make sure everything is disconnected, is the clip light still on?
if so then I'm afraid it sounds like the output devices for one channel may have blown, ( not certain, without looking at it i'm afraid ).
If you need more help, then please ask.
Regards - Anthony
Posted on Feb 06, 2010
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
One side dead
hi zm_16dec,
Right chanel fully dead , output transistor burnedout ,
Without knowing the make and model of your amplifier
all i can advise is to replace the unknown part number of
the transistor.
Look for the working left channel output transistors and
replace the bad transistors in "pair". These may include
other components but check on it as well.
Check the speaker system, especially where that channel
is connected.Inspect speaker wires or cable up to the speaker
itself.
Amplifier wont blow without reason.It could be from the wirings,
speaker or volume settings of the unit.
Thanks for choosing Fixya for assistance!
Dec 24, 2012 | Audio Players & Recorders
I have 4 speaker wires, black green red white speaker left + speaker right + speaker left - speaker right - which cable goes where?
4 speaker wires, black, green, red, white ;speaker left +speaker right +speaker left -speaker right. First see what pair of speaker wires go to left the channel of the amplifier. One of each speaker must be connected to each amplifier´s channel, no matter of colors of the wires. Two wires for each speaker to each channel of the amplifier (rear panel + and -). Then you will have 4 wires connected to 2 stereo channels of your amplifier. Two wires for each speaker.
Sep 17, 2010 | AudioSource Amp Four 2-Channel Amplifier
The left side of the output is hot and the right
switch cables of the outputs to speaker if the fault transfer to the other side you will have an internal problem and you must pass it to service center.
Jan 07, 2010 | Yamaha P3500S Amplifier
AUDIO AMPLIFIER'S ONE CHANNEL DEAD
Hi there.
Check for shorted speaker wires on left channel. If not, disconnect speaker wires and check to see if headphone jack works. If left works, you may have a blown speaker. If left still doesn't work, left power amp blown.
Thanks
Paul
Jul 06, 2009 | Sony Audio Players & Recorders
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Help
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Feb 15, 2008 | Boss Riot 1500D Car Audio Amplifier
Speaker problems
Hi, since the speakers themselves are ok, try checking the BABY PHONE PLUG that goes to the music/sound source. It is normally three (3) in 1 stud. The metal topmost would go to one channel, followed by a blak plastic ring then another metal band which goes to the other channel, followed by another black plastic ring and the final metal part which is the ground. With power on to the Z-5300, try touching the ends of the baby phone plug. Touching the top and 2nd metal part should produce a sound on either of the left or right. No sound (but spkrs good) it is possible that the left channel (front and rear) of the amplifier is dead. Hope this helps.Regrads.
Apr 20, 2007 | Logitech Z-5300 Computer Speakers
Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Jan 17, 2007 | NAD C350 2-Channel Amplifier
Yamaha P3500S Amplifier Logo
223 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
