Hi, I've got a PC which last time can't swich on. After pressing power button hundreds of times, finally boot up and working fine, but after I switch off can not start up again. The power button sounds fine, PSU? or try something else? Cheers
    Problem Solver:
  • 6 Answers
Try to switch the mainboard on direct with another switch, if you do not have another switch, locate the 2 pins for the power switch an use a screwdriver to conduct each pin to turn its power on, but be careful, and try not to touch any other pins, and ground youself with the pc`s case first.
Posted on Feb 06, 2010
    Guru:
  • 161 Answers
Do you know how to turn on your pc just shorting inside the motherboard???
try that if it works.. it means your button is the problem if not..
your power supply is the problem..
hope it's a help..
rate this plz..
I have
Really? Wow!
1) Is the spring clip in the CMOS battery holder, weak, or has it been bent?
2) + of battery is facing UP, right? (Positive = + )
Don't know if it would even work in the other direction, but you learn something new everyday.
3) CMOS battery holder soldered tightly to the motherboard?
The motherboard mounts to a Support Plate.
The Support Plate can be part of the computer case, or a separate plate that is mounted to the computer case.
4) Is there dust in-between the Support Plate, and the motherboard?
You know, -> 'dust bunnies'.
Post back in a Comment.
Regards,
joecoolvette
Jul 29, 2012 | Computers & Internet
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
Hi ...i'm running XP SP3 on my HP NC6320 and it keeps rebooting with the "bluescreen msg" in between which i'm not able to read because it lasts for less then split of a second.It wont boot in...
Try clean boot.
Final, Back up the data ,Do the Clean installation.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Dec 17, 2010 | HP Compaq nc6320 Notebook
Sir i have a my phone nokia 7210 when swiching on the phone display showing white light, give me a some solutition
You can try this
switch off your phone then press
* , 3 and call button
hold these 3 keys simultaneously and switch on your phone without releasing the keys
then your phone will get formatted....
this also works
power it on and press the * key 5 times this should clear memory and the phone should now continue to boot up
Aug 11, 2010 | Nokia 7610
Nokia 6500S turns of every 1-2 seconds. How can i format memory?
first of all you should replace your mobile battry .if problem d 'nt solve then press * 3 , power on button and menu button at same time.first press * with 3 with menu with power on swich
Apr 11, 2010 | Nokia 6500 Slide Cellular Phone
My Acer extensa4420-5963 has been acting funky for the last three/four days. Started out my date and time went haywire. Clock kept losing time as soon as laptop was turned off and reverted to battery. Then...
First of all the RTC (real time clock, BIOS/CMOS) battery has run out. This means the computer cannot keep the date and time when its turned off and disconnected from the mains. You will need to take the laptop to a reputable PC repair store and have them fit you a new CMOS battery.
As for the power on problem, this well could relate to the CMOS battery being drained but also could be a number of different reasons why it won't power on properly.
In my experience laptops that have problems powering on is either to do with the DC adapter on the laptop that has a dry solder point or the power board is failing.
Either way i would take the computer to be looked at.
Regards.
Jan 25, 2010 | Acer Computers & Internet
Compaq Presario R4000 Notebook won't boot
Seem to be a problem with your power switch doing malfunction or bad motherboard connector or your computer has been setting at hibernate mode. Check those settings going to >> Start >> Control Panel >> Power Options..........Set your droplist to "never: and also UNCHECK the hibernate mode.
Another tip, take out the battery, and see what happen (only connected with AC)
Oct 13, 2008 | Compaq Presario R3000 Notebook
NEC Versa s970
when the bluetooth and wlan light are off press the wireless button three times and wait a sec and it will work. thats what nec told me
Apr 16, 2008 | NEC Versa LX Notebook
k24674
jasbo
jasbo
