Question about Seagate Barracuda 7200.7 200 GB Hard Drive
Seek rate problem in Seagate 200 GB
I have Seagate 200 GB PATA 7200 RPM harddrive..... I had purchased the harddrive in April 2007, recently when
I diognised the harddisk health with "Harddrive Inspector"... I came to know that it was in bad health and the seek rate was just 6%....
I am really worried about my data... the harddisk is full with data just about 3-4 GB are left empty.... Right now I have Disconnected the harddrive as I used to keep it as slave one...
I am really worried about harddrive and especially the data... please provide me a solution...
  • 13,433 Answers
Hey, I recommend you test the harddrive with seagates own tools.
http://www.seagate.com/www/en-us/support/downloads/seatools/
I recommend the dos version.
Also try active smart
http://www.ariolic.com/activesmart/index.html
I would recommend backing up all the data from the drive, and then if the drive still has problems You should send it for warranty repairs. Shouldnt cost a thing.
You can also take it to a local pc repair shop to get all the data copyed and then sent to warranty service if nessasary it will cost thought if you do it via a shop.
Posted on Feb 21, 2008
  • Ekse Feb 21, 2008
    Nevermind about Active smart, hdd inspector seems to be a good product il check what it tells me about my two hard drives.
I looking for a pcb boad for hd western digital
That would be on another WD2500JB Caviar harddrive
Either that, or start looking on the internet posting -
WD2500JB PCB Board, and see what search hits come up.
Here,.....let me try.............
http://www.hdd-parts.com/18100096.html
Before you replace it, let me ask........
1) Was it in a Desktop PC?
2) Was it in an external harddrive?
External harddrive?
Then suggest you obtain a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3883498&CatId=2780
In an external harddrive there is a small interface circuit board.
The Harddrive plugs into the small interface circuit board, and the USB cable is attached to the small interface circuit board.
It is this small interface circuit board that usually goes bad.
The external enclosure is just like the case of the external harddrive.
Has a USB cable going to a small interface circuit board, and the harddrive plugs into it.
Regards,
joecoolvette
Mar 13, 2013 | Western Digital WD2500JB WD Caviar EIDE...
I have a Seagate external hard drive model # 9w6044-500. I need to know what kind of drive it has, how many gigs it is and what size disc it uses.
Welcome to Fixya. Here's the specs of the hard drive
MPN: 9w6044-500
Capacity: 160 GB
Interface: USB
Enclosure: External
Spindle Speed: 7200 RPM
Special Features: Vertical or Horizontal Placement
Internal Data Transfer Rate : 464 Mbit/s
External Data Transfer Rate: 60 MBps
Seek Time: 8.5 ms
Buffer Size: 8 MB
Average Latency: 4.17 ms
Interface (Detailed): USB 2.0
Hot Swap: Yes
Platform: PC, Mac
Height: 2.25 in.
Width: 6.5 in.
Depth: 7.13 in.
Weight: 2 lb.
If you have questions please let me know. Thanks for using Fixya.
Mar 13, 2011 | Seagate (9W6044-500) 160 GB Hard Drive
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
I have a Seagate Free Agent Pro GB HD. Recently purchased a a new computer and cannot locate drivers for this equipment, can you recommend a site where I can download?
Hi and Welcome to Fixya,
Here is the download site from Seagate http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Please check that link and then download the driver for your device.
Jan 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seafate Freeagent Harddrive not recognized
is the drive shown in device manager? if not the drive is at fault.
Mar 26, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
CDBOOT: memory overflow error.
Hey there,
At first you need to tell me whether ur hard drive is sata or pata.
If u r having Sata drive then this error occurs due to absence of SCSI Controller driver.
Else if u r using PATA Drive then Try change the bios ssetting.
Go to advanced --> Sata Configuration --> and then disable SATA native mode.
Try out above mentioned solution it'll surely help you.
Thanx.
Gimme your acknowladge by rating my solution.
Romy
Dec 24, 2008 | Intel Desktop Board D845GERG2 Motherboard
Seagate 500 Gig External Drive disappeared !
external harddrive turn them selves off after 5 minutes if it isn't being used.
Aug 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Barracuda 200 GB 7200 RPM
can you take a snapshot from the smart page?
Feb 22, 2008 | Seagate Barracuda 7200.7 200 GB Hard Drive
Seagate Barracuda 7200.7 200 GB Hard Drive Logo
217 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
