Question about Bosch WFL 2063 Front Load Washer
Bosch washing machine not getting hot
Hi there, my bosch wfd 2473 does not get hot - any ideas? cheers, Toni.
  • Anonymous Mar 18, 2014
    program not ok
  • Anonymous Mar 23, 2014
    How do I remove the spinning drum?
  • 49 Answers
One of 2 things, eather the element is faulty or the electronic control board wich puts power to the element is faulty.
more likely to be the element
Posted on Feb 21, 2008
Bosch wfd 1060za/01
sounds like need to be replaced they are known to wear out the hard water and soap deposits wreck havic on the switches, especially if its a digital lock switch system
Jul 25, 2014 | Bosch Washing Machines
Bosch wfd 1060
Sounds like the door lock, before getting a new one check it's not just the connection come adrift. Isolate from mains, open door, remove retaining spring from around door gasket and you can access the door lock (usually held in position by two Torx20 screws.
May 23, 2013 | Bosch Washing Machines
I have a bosch wfd 2473 washing machine it will not pump or spin, i have removed the water by releasing the filter there is nothing within the filter and the pump spins quite freely .i could not syphon the...
bosch wfd 2473 washing machine it will not pump or spin This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 27, 2012 | Washing Machines
Where can I get a user manual for a Bosch WFD2071?
Hi.
Please click on the link below to download the manual for Bosch WFD2071 in PDF format.
User manual: WFD 2071/2072/2073
Regards.
Ginko
Sep 09, 2011 | Washing Machines
Bosch WFD 2473 - wont spin. I've taken out the filter and found a broken washer in it. Can't work out where the washer comes from? Doesn't seem to fit the filter. Having cleaned the filter, washing machine...
Even if the pump is not working, then so long as there is no water in the washer, it should spin
If it does not, then I would suspect the motor brushes are worn out.
You need to remove the motor to check the brushes, if they are less than 2 or 3 mm long then they need replacing.
I do not think the washer you found is off the pump,more likely out of someones pocket.
Hope this helps with your problem.
Dec 02, 2009 | Bosch WFL 2063 Front Load Washer
Where I can get manuals for Bosch WFD 2060 washer
You can find users manuals at; www.managemyhome.com
You will need the model number off the product ID tag affixed to the unit.
The search box is on the right side of the page.
Jul 12, 2009 | Bosch Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
Jul 23, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch WFL 2063 Front Load Washer Logo
261 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
