Question about Dell Computers & Internet
My inspiron 1520 normaly working , after 10 minute. laptop restart hi self,
  • 712 Answers
Pull the memory stick(s) out of the motherboard and run a single 1x512 in the top slot (under the keyboard) as well as remove the bottom cardslot device as the motherboard had a short causing this on the bottom half (where heat builds up). With these limits (max 512mb and no bottom cardslot usage). It will work great now.
Posted on Feb 06, 2010
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I forget my MY dell inspiron 1520 Laptop of vista basic OS's password and later on typing wrong password it also blcok the system and displays messag
Crack Dell Laptop Password
U can search the above words via search engine and get ideal suggestion from search results!
Then, there will be solutions supported:
Step 1. Access other PC which isn't locked, download the Windows Password Recovery Tool 3.0, install and run it.
Step 2. Burn a password reset disk. You can choose CD/DVD or USB.
Step 3. Connect the nearly created disk with the locked Dell laptop, config bios setting to make sure it boot from the password reset disk, reboot the computer.
Step 4. Choose the user that you forgot its password, click "reset" button to begin crack its password.
Step 5. A message box will pop up, just click "Yes", then the user's password will be cracked to blank.
Step 6. Disconnect the password reset disk, and restart Dell laptop. You will login Windows with a blank password.
Hope it helps you!
Nov 21, 2011 | Dell Inspiron 1520 Motherboard
Hi my dell inspiron 1520 not starting when power button is switched on..the power light blinks and goes off..and the system doesnt start. I had shown the laptop ito dell service center and they have...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
But, if you paid for the Dell service, Dell needs to fix the problem. Sounds like they replaced the motherboard with another faulty one.
Hope this helps.
Feb 12, 2011 | Dell Inspiron 1520 Motherboard
I have a Dell Inspiron 1520 laptop. Fan has gone
that is absolutely right i work for the same and we charge $49 If you bought the sys. after sept. 2004. and you are out of warranty.***let me know what is the blue screen all about.and stop erros code with 0x000000** this blue screen will help us to understand the issue. and i can help you to resolve your issue.
Nov 06, 2009 | Dell Inspiron 1520 Motherboard
Dell 1520 wi-fi not working I have two laptops and one will not work with the wi-fi
sounds like you have one laptop set up for wireless and one that is not.
Aug 17, 2009 | Dell Inspiron 1520 Motherboard
Some characters on keyboard not working
Restarting the laptop usually resolves this issue. However, if you are frequently having the same issue, or if restarting did not help, i suggest that you contact dell technical support to check for possible serious problem on your keyboard. you may visit www.support.dell.com
Jul 09, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Usb and webcam problem with a Dell Inspiron 1520
http://www.driverdownloadcentral.com/top.php?csvkeyword=USB-2.0-Drivers try downloading some drivers so that your usb ports connect wth the software on your computer. Really hope this helps.
Jun 24, 2009 | Dell Inspiron 2200 Notebook
My dell inspiron 1520 won't start up the caps light blinks and the other two lights stay on nothing comes up on the screen my drivers won't open my wifi light doesn't come on any help would be appreciated...
You can unplug the laptop and also remove the battery for 15 minutes.
Put battery back, plug it in and restart.......
Also check that AC Adapter is working properly,
Another common cause is memory module failure.
Test memory modules, or replace for new ones.
Hope this helps
Jun 10, 2009 | Dell Computers & Internet
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
