Question about Dell Inspiron 1000 Notebook
I swiched off my laptop inspiron 1000 at the off switch. when I put it back on the back light did not work
  • 1,188 Answers
How do you know it is the backlight? Usually people think that's it but it is the inverter.
f the backlight of your laptop stopped working and the image on the screen is so dim that you can barely see it under bright light, most likely you have a failed inverter board. There is a good chance to fix the problem if you replace the inverter board. If you replace the inverter board but the image is still dim, most likely there is a problem with the backlight lamp inside the LCD screen. If that's the case, try to replace the LCD screen. Note: it's much easier to disassemble the laptop display panel when the display panel is separated from the laptop.
I can definitely fix either way if you are out of warranty from dell.
Good luck! EJ Kudelka ej@outlet3g.com 516-860-2969
Posted on Feb 06, 2010
What causes the break light swich to push, ive took apart the swich and can push it and break lights worked but when i put swich back on with clip it dose not work when i hit the break peddel
nothing, It doesn't work like that, when your brake switch is mounted , correctly , your pedal has a bracket on it that pushes the switch plunger in so brake lights are off. when you push brake pedal in, to stop vehicle, the switch plunger (spring loaded) comes out to turn brake lights ON ! get it ? when you release pedal it pushes plunger in, to turn lights OFF !
Jan 15, 2013 | 1997 GMC Sierra
Last fre days i didn;t use my laptop. today i tried to put on. it is not swich on. no lights. what ahppend plz help
Remove the battery, remove the power plug, press the power button for 5 seconds. Plug the machine back in but do not put in the battery, try to power the machine on.
Mar 15, 2011 | Dell Inspiron 1545 Notebook
Getting wireless to work on my Dell Inspiron 1000
find switch on laptop it is wi fi network adapter switch on laptop turn on it.
Then also check your wi fi drivers are installed.
if driver are not install for wi fi downlaod from here in netwrok
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_CEL_1000&os=WW1&osl=en&catid=&impid=
then install wi fi then check.
Jul 14, 2009 | Dell Inspiron 1000 Notebook
My Dell Laptop will not power up! Dell inspiron 1000 notebook
take the cmos battery out and put in the power cable, and start the machine
Mar 26, 2009 | Dell Inspiron 1000 Notebook
I have a inspiron 1000 pc notebook and it has a wifi but it says that it is not switched on. how do i swich it on, so i can use the net.???? help any one
Check around the sides of the laptop. There is usually a switch. It's not always easy to find so look carefully. If that doesn't work report back and I'll give you another tip.
Feb 20, 2009 | Dell Inspiron 1000 Notebook
Vertical Fold over or rolling on Dell Inspiron 1000
Get a new hard drive put into the system, with the cd's that came with the system, restore the laptop back to factory defaults and then after that the F12 function should work and windows will go back to working as well.
Feb 13, 2009 | Dell Inspiron 1000 Notebook
Dell inspiron 1000 power lite comes on then goes off cd works, num lock lite on, screen not on and then power light goes off other lights on and cd works, hd light not on.
Motherboard failure. You can find replacement motheboards on Ebay but this is such a low end system it isn't really worth repairing
Jan 20, 2009 | Dell Inspiron 1000 Notebook
HP PAVILION 1000
If you put the old inverter back on and the system works, I'd suspect the inverter is bad. If the system is still a no post after putting on the old inverter, then you may have a motherboard problem now.
Apr 30, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1000 Notebook Logo
112 people viewed this question
Alun Cox
