Question about Dyson Ball DC24 Bagless Upright Vacuum
The roller will not spin.it is free to move with your hand
Kirby roller
the brush bar has 3 settings marked on the end of the plastic clips that hold the bar in place make sure it is set to no 2 both ends,lay machine down and start roll should spin also check bar is free to move by hand
Jan 18, 2014 | Kirby Heritage II Vacuum
Hi,dyson dc25 overdrive,my brusher's wont go round,i have cleaned the brusher's and filter,loads of suction.the belt is intact and the roller move's feely by hand,could it be the switch
Hi Stephen,
I'm sorry to hear you've had difficulty with your DC25 Overdrive. If the brush bar won't rotate, and you've already checked the cleaner head is free of obstructions, it's likely it just needs resetting.
You might like to take a look at the video below to make sure everything is correct with the machine. Once you've done this, if you turn the machine on, recline it into the vacuuming position, then press the silver brush control switch twice, this should reset the brush bar.
If you'd like any further assistance or advice, please give our Helpline a call on 0800 298 0298. Just to let you know, calls are free from UK landlines, and the Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Aug 01, 2012 | Vacuums
How to change drive belt on bissell vacuum cleaner
Hello, you will need to take the bottom plate off, remove the screws on the plate, then pull up and out the brush roller, clean off any hair on the roller, make sure it spins freely, then put a new belt around the metal motor shaft, then around the roller and pull in down into the housing, spin the roller to make sure it moves freely, so you don't burn up the new belt, put the bottom plate back on and your ready to vacuum. Any questions feel free to call @ 1561-848-3387 I'll be gflad to help, Thank you, Teresa. Clean Sweep Vacuums
Aug 10, 2010 | Bissell 6594 PowerForce Bagless Upright...
The brush on ours wont spin
Take out the brush roller. (turn the plastic lock mechanism with a coin or screwdriver, pull out the plastic holder, and the brush will pop out). The brush roller has two white caps on the ends. Chances are, one or both of these caps have moved out just a bit, putting too much force on the delicate motor. Simply push the caps back firmly into place. Make sure the brush and the surrounding area is clean, put back in and It should spin .
Feb 25, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Roller bar (barush bar) does not turn
u may be able to turn it by hand, but stuff "hair" is not letting it turn like it should. this unit comes apart vary easily. clean the ends of the brush bar and the housing where it sets, after it is removed. u will see that it should free spin.
Oct 02, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
May 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Mar 21, 2009 | Vacuums
How to replace vaccum belt on a hoover tempo
Turn the machine upside down. Take the screws out of the bottom plate and remove it. take out the brush roller and old belt. Wrap the new belt around the metal shaft of the motor first and put the roller inside the belt loop and use the roller as leverage to stretch the belt up to the brush housing and slide the roller in place. Give the roller a spin by hand the make sure everything moves freely before you use it. It should spin with out much effort, if it doesn't you probably have the belt pinched, and you need to free it up before putting the bottom plate back one. It will take a little elbow grease, but it will go on.
Hoovers usually list what kind of belt they take on the serial tag.
Good Luck
Nov 22, 2008 | Hoover Vacuums
No manual
Take the hood off of the unit, and remove the brush roller and belt. Wrap the new belt around the shaft of the motor and slide the brush roller inside the loop of the belt. Use the brush roller as leverage to stretch the belt out and slide the brush roller back into the roller housing. Once you have it installed correctly, make sure the roller and belt are free, by spinning it by hand. If that belt is pinched it will just burn it up when you turn the unit on.
Good luck
Oct 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
May 18, 2008 | Dyson DC07 All Floors Bagless Upright...
Dyson Ball DC24 Bagless Upright Vacuum Logo
64 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
