Question about Stoves 720EF Electric Double Oven
How do i take the door off to clean it - Stoves 720EF Electric Double Oven
  • 250 Answers
To take the door off you have to remove inner glass panels from both doors. Then remove the appliance from the housing unit. When the unit is out, you then have to unscrew the top panel and both side panels and lift them clear.
With the door closed, support it with one hand as you carefully unhook the large springs from the door hinge arms. The door frame can now be removed.
The above is from the handbook. You can actually remove the outer glass panel as well but personally would just slide the inner glass panel out and clean the door in situ.
Posted on Feb 06, 2010
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
Oven door locked.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F9 code comes on frigidaire stove when self clean operation starts, i cleaned around door lock, what should i do next
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#!#
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Wife was trying to clean (self cleaning oven) and after setting timer the oven door will not lock and it will now not let us do anything now and it shows a f9 code and when i press bake control, dr shows...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^&^%^%
Dec 14, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Llock light is on but door will not lock to clean oven
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$%^&
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self Cleaning problem
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question)(*&^%
Oct 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self Cleaning error F9
Stoves 720EF Electric Double Oven Logo
198 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
