Question about Jobo Giga One, 120 GB Portable Memory Card Backup Storage Device with USB 2.0 Interface. MP3 Player
If i switch it on, it says error 1 and i can't transfer data
  • 80 Answers
It needs to be formatted. YOU NEED TO FORMAT IT.
Posted on Feb 06, 2010
How to transfer everything ftom my samsung galaxy 3 to a samsung sJ
With an android data transfer tool, you can transfer data fom one phone to computer, and import them to your another phone. Hope this helps you,
MobiKin Assistant for Android Windows Version
Dec 27, 2015 | Samsung Cell Phones
Data Transfer error
You need new lower power board some people say lower circuit board . This will cost around 280 but anyone looking to buy I have got one brand new.contact me on 07943858686
Mar 14, 2012 | Tunturi T85 Treadmill
Scanner error 20
hello,
this error 20 means insufficient memory so the printer received more data than can process,there ore two solutions :
1.instal aditional memory
2.press GO to print the transfered data(you may lose some data)
Mar 03, 2012 | HP LaserJet M1005 Printer
TEC B 572 WHEN USING DATA TRANSFER SWITCH BOX.. ERROR CODE SG;0040,1120,1384,00 APPEARS ON 1 MACHINE.
This may be a firmware problem! or problem on the communication port
This is a syntax error detected by the machine
Aug 01, 2011 | Toshiba TEC B-472 Thermal Label Printer
I receive the following error message, when I power on my Copystar CS 300ci: Machine Failure C1950 Any suggestions
Transfer belt unit EEPROM error No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively. Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively
1. Poor contact in the connector terminals.
- Check the connection of connector YC28 on the engine PWB and the connector of the transfer belt unit, and the continuity across the connector terminals. Repair or replace if necessary.
2. Defective transfer belt speed PWB (inner transfer belt unit).
- Replace the transfer belt unit.
I hope this is helpful,
Shawn
Mar 14, 2011 | Kyocera Copystar CS2540 Copier
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
How to fix the error code for Ricoh 1232c sc517 and how to clear it
there's no error code like that
http://www.unitedtechsonline.citymax.com/page/page/4653767.htm
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER)
384-385:IMAGE DATA TRANSFER PROBLEM WHEN TANDEM IS USED(SBU,INTERFACE
BOARD,SICU,PRINT CONTROLLER)
390:TANDEM IMAGE DATA TRANSFER ERROR(NOISE,SICU,INTERFACE BOARD)
391-392:IMAGE STORAGE ADDRESS ERROR(SICU391-01)
395:CD-R/RW ERROR, INTERFACE BOARD ISSUES
397:CD ACCESS ERROR
398:CD-R/RW DATA ERROR
400:TRANSFER BIAS ROLLER ISSUES
401:TRANSFER ROLLER
430:QUENCHING LAMP ERROR
440:DRUM MOTOR LOCKED
441:DEVELOPER MOTOT LOCKED
491:LASER COOLING FAN LOCKED
495:TONER BOTTLE PROBLEM
496:TONER COLLECTOR BOTTLE PROBLEM
501:LIFT PROBLEMS FOR TRAY 1
502:LIFT PROBLEMS FOR TRAY 2
503:LIFT PROBLEMS FOR TRAY 3
504:LCT 1ST TRAY PICKUP OR LIFT PROBLEM
505:LCT 2ND TRAY PICKUP OR LIFT PROBLEM
506:LCT 3RD TRAY PICKUP OR LIFT PROBLEM
510:PAPER FEED MOTOR PROBLEMS
511:LCT MOTOR PROBLEM
515:TANDEM REAR FENCE MOTOR PROBLEM
520-521:DUPLEX JUGGER MOTOR PROBLEMS
531:FUSING DUPLEX MOTOR LOCKED
532:RELAY MOTOR LOCK
541:OPEN FUSER THERMISTOR
542:LOW FUSER TEMPERATURE
543:HIGH FUSER TEMPERATURE
544:HIGH FUSER TEMPERATURE
545:HIGH FUSER TEMPERATURE
546:LOW FUSER TEMPERATURE
547:ZERO CROSS PROBLEM
550:WEB EXPIRED
591:TONER SUPPLY MOTOR PROBLEMS
592:TONER BANK MOTOR PROBLEMS
601:SBICU TO SBU COMMUNICATION PROBLEMS
602:SBICU TO HARD DISK DRIVE BOARD COMMUNICATION PROBLEMS
620-622:SBICU TO ADF COMMUNICATION PROBLEMS
625-626:BCU TO FINISHER COMMUNICATION PROBLEMS
630:LINE ADOPTER TO CSS CENTER COMMUNICATION PROBLEMS
640-645:BCH TO SICU COMMUNICATION PROBLEMS
646:SICU PROBLEM
650-653:COUNTER ERROR JAPAN
701:ADF P/U ROLLER PROBLEMS
702:ADF FEED MOTOR PROBLEM
703:ADF TRANSPORT BELT MOTOR PROBLEM
704:ADF EXIT MOTOR PROBLEM
705:ADF ORIGINAL TABLE LIFT ISSUES
720:FINISHER LOWER TRANSPORT MOTOR ISSUES
722:FINISHER JOGGER MOTOR ISSUES
724:FINISHER STAPLER HAMMER PROBLEMS
725:FINISHER STACK EXIT MOTOR PROBLEMS
726:FINISHER SHIFT MOTOR PROBLEMS
727:FINISHER STAPLER ROTATION PROBLEMS
729:FINISHER PUNCH MOTOR PROBLEMS
730:FINISHER STAPLER MOTOR PROBLEMS
735:FINISHER PAPER STACK PLATE MOTOR PROBLEMS
736:FINISHER EXIT GUIDE MOTOR PROBLEMS
737:FINISHER FULL STAPLER HOPPER
738:FINISHER SHIFT TRAY LIFT MOTOR PROBLEMS
739:FINISHER FOLDER PLATE MOTOR ERROR
740:FINISHER FRONT SADDLE STITCH STAPLER MOTOR PROBLEMS
741:FINISHER REAR SADDLE STITCH STAPLER MOTOR PROBLEMS
742:FINISHER JOGGER SIDE FENCE MOTOR
750:COVER INTERPOSER BOTTOM PLATE MOTOR PROBLEMS
800:VIDEO OUT TRANSFER,CONTROLLER BOARD
804:VIDEO OUT TRANSFER,CONTROLLER BOARD
818:OPTIONAL BOARD,CONTROLLER BOARD, SYSTEM PROGRAM
819:BAD SOFTWARE
820:CONTROLLER BOARD OR SOFTWARE
821:CONTROLLER BOARD
822:HDD PROBLEM
823:NIB, CONTROLLER BOARD
824:CONTROLLER BOARD, NVRAM
825:NVRAM ERROR
826:NVRAM
827:CONTROLLER BOARD, RAM
828:SOFTWARE,ROM,CONTROLLER
829:RAM, CONTROLLER
835:CONTROLLER,CENTRONIC LOOPBACK CONNECTOR
836-837:FONT DEVICE
838:CONTROLLER BOARD
850:IP ADDRESS,CONTROLLER BOARD,NIB
851:1394 I/F CONNECTIONB,I/F INTERFACE,CONTROLLER BOARD
860-861:HDD
862:HDD BAD SECTORS
863:HDD
864:DATA TRANSFER ISSUES
865:HDD
900:NVRAM PROBLEM.ELECTRICAL COPY COUNTER
901:MECHANICAL COUNTER ISSUES
921:IMB, BICU FAILING
922:IMB, BICU FAILING
924:DRAM,BICU,IMB FAILING
925:BICU, IMB FAILING
926:BICU, IMB FAILING
951:F-GATE SIGNAL ERROR PROBLEMS
953:SCANNER IMAGE SETTING ERROR ISSUES
954:PRINTER IMAGE SETTING ERROR ISSUES
955:MEMORY SETTING ERROR ISSUES
964:PRINTER READY ERROR ISSUES
966:POLYGON MOTOR PROBLEM
970:SCANNER READY ERROR
980:HDD ACCESS ERROR
981:BICU, NVRAM
982:HDD CONSTRUCTION ERROR
984-987:HDD DATA TRANSFER ERROR
990:SOFTWARE PERFORMANCE ERROR
991:REBOOT SOFTWARE ERROR
997-998:DIMM, RAM ERROR
999:PROGRAM DOWNLOAD ERRORS
Oct 29, 2008 | Ricoh Office Equipment & Supplies
Transfering data from one desktop to another
sol 1 you can burn your data in dvd or cd
sol 2 you can transfer your data in thumb drive (pen drive)
May 31, 2008 | Dell Dimension 4600 PC Desktop
Brother 7820n
User maintenance mode is -
Menu/Set
, Start, Menu/Set , and keys in this order
The function you can change are -
06 Placement of CIS Unit Position for Transportation
09 Test Pattern 1
10 Firmware Switch Setting
11 Printout of Firmware Switch Data
12 Operational Check of LCD
53 Received Data Transfer Function
54 Fine Adjustment of Scan Start/End Positions
80 Display of the Equipment's Log Information
82 Machine Error Code Indication
87 Output of Transmission Log to the Telephone Line
99 is to exit.
Feb 04, 2008 | Office Equipment & Supplies
Jobo Giga One, 120 GB Portable Memory Card Backup Storage Device with USB 2.0 Interface. MP3 Player Logo
110 people viewed this question
Top Jobo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jobo Audio Player and Recorder Expert? Answer questions, earn points and help others
