Make sure that you leave the unit plugged in for two hours, and remove the sd card, if you have a card in it.
On the top or bottom of the unit is a usb port and a reset button, take a paper clip and open it, then put the paper clip into the little
reset hole and push in for 30 seconds.
Turn on unit, hold the on button for 5 seconds, now turn off, now hit the reset button again as said above and then power on and run though
your menu and see if this did the trick, if not you might have to send the unit in for repair.
Please post back if you need any more help.
