Question about Siemens Washing Machines
Reset childproof lock siemens washerWM16S760DN
    New Friend:
Reset childproof lock siemens washer dryer wd12d523gb?
Posted on Jul 18, 2013
Set it to the last programme you had it on then press and hold the timer button for about 5 seconds.
Posted on Jun 20, 2010
NN-ST671S microwave is locked and wont function Is their a childproof lock on it and how do you unlock it
There should not be a childproof lock on your microwave.
However, it is remotely possible that there is electrical failure preventing the door opening.
Most, not all, microwaves can be taken apart with screws with the door closed.
See if you can do yours.
You should find the latch holding the door is broken or stuck or whatever.
God bless your efforts.
Nov 13, 2017 | Microwave Ovens
How do I deactify a childproof lock on Siemens washing machie
Google your make, model and manual to locate your manual. Refer to your manual.
Mar 08, 2015 | Siemens Washing Machines
How to turn off childproof lock on remote
hold down the mode button and the up arrow button at the same time
Dec 24, 2013 | Heat and Glo Home
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
Bosch logix8 comming up with the code nro
Bosch Logixx 8 error code nr0 means - The childproof lock has been activated.
Just deactivate the childproof lock.
Apr 10, 2012 | Bosch Logixx WFT 2806 Front Load...
How do you deactivate the childproof lock on Siemens IQ 1633 washing machine? The wash cycle has finished and I cant open the door as the childproof lock is on. I do not have a manual.
Couple of things-
Just in case no-one else answers (I don't know how to release the child lock on your particular machine) methinks you need a manual! You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
Now- is it showing 'child lock' on or just not releasing the door?
If it's just the door I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 16, 2011 | Siemens WIQ1633 Front Load Washer
I have siemens washer serie IQ 1431. My door will not open and the washer is full of wash.How do i get the door to open?
Cause The childproof lock has been activated.
Resolution Deactivate the childproof lock. Directions can be found in your instruction manual.
The manual for your washer can be fount at at the following website. You will need the E-Nr number in order to get the correct manual. You can find the E-Nr Number on the rating plate of your home appliance.
Mar 08, 2011 | Siemens Washing Machines
Childproof lock on
May I get the make and model # to help you more.
Apr 18, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
WD12D520GB
IF IT IS LIKE MY 5202 YOU HAVE TO PRESS AND HOLD THE UNLOCK BUTTON FOR LIKE 3 SECONDS. THIS PREVENTS SOMEONE FROM JUST PRESSING THE BUTTON AND ACTIVATING THE LOCK . TRY THE PRESS AND HOLD METHOD AND LET ME KNOW.
Dec 19, 2008 | Siemens WIQ1433 Front Load Washer
Childproof Lock
Hello mine is a WM14S79BUK but i think it works on most recent models with lcd display.
I have to hold the down button on the option buttons for 5 seconds to activate child lock or unlock
it's worth A TRY
Hope this helps
Jun 07, 2007 | Siemens WIQ1433 Front Load Washer
Washing Machines Logo
921 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
