Question about Gigabyte GA-EP45-UD3P - Motherboard - ATX - iP45 - LGA775 Socket - UDMA133, Serial ATA-300
Motherboard gets power and shows all the phase lights (6) on but never gets to post. I know the ram, gpu and cpu work. How can I tell if it is the motherboard or a bad power supply. I do not have another ps to try.
    Guru:
  • 161 Answers
Are you sure all of your parts are in good condition??/
like your memory why do say that it is ok???
your video card??built in???
you can say that it is mother board in this..
do you have a speaker??the one that you can connect directly inside your motherboard,we call it built in speaker...some casings have it... it will produce a beeping sound and it gives a greate help for..you can determine if what part of hardware inside your CPu has the problem...
i hope i've help you..rate me...
Posted on Feb 06, 2010
Flashing red light on my hp..no beep...no display
ok if the motherboard ram and cpu are good it will boot to bios if the screen and gpu works ull then get a picture
my asumption is a dead part
cpu
ram
motherboard
2 ways to tell pay a shop about 20.00 for a diagnostics test
or try replaceing parts
the fact u got lights is good means its proberbly not your motherboard
so proberbly cpu or ram
what model is it ?
find that out and google it ie hp d123 specs
ull find all the specs for it what ram it takes what cpu it takes
do u have spares?
maybe get cheep cheerfull parts from ebay that have been tested and work
its that or if u have another pc that supports the same ram or cpu then put the parts from this in to that pc to test if they work
Oct 30, 2012 | Computers & Internet
I need info about what the cpu phase leds on aN msi 990fxagd65 mean
They indicate the number of different power phases that the CPU is currently using. In order to save power the motherboard is able to reduce the voltage to (and performance of) the CPU. In 2 phase mode (2 LEDs) it basically switches between high performance, and low performance. 4 LEDs means that there are two additional intervals in between the high and low power settings. 6 LEDs indicate six total phases, etc.
I believe that there is a greater possibility of system instability as you increase the number of phases that the motherboard switches through.
Oct 22, 2012 | MSI 990fxa-gd65 Motherboard Am3 Amd990fx...
My pcg-fx220 vaio laptop has what looks like battery 1 flashing yellow light. I start it up but it doesn't get past the sony start up screen the little light just keeps blinking. It's plugged in so...
Take out the battery, plug it in turn it on, if the problem is the same unplug it. Turn it over and remove the access panel from the bottom. There you should find your RAM if you have two RAM modules installed remove both and replace them one at a time with the power off. So insert one and power on computer if the same result as before, remove it and insert the other RAM and power it on again. Also look to see if your CPU fan is spinning. If your fan only spins for 5 to 10 seconds and powers off one of three things are bad, either your CPU, GPU, or Motherboard are bad or damaged. It might turn on here or there if this happens it's probably your GPU. Hope this helps you.
Jun 28, 2011 | Computers & Internet
I HAVE AN HP PAVILION P6310Y WITH 6 GIG OF DDR3 1 TERA HD NVIDIA GEFORCE 9100 INTAGRATED GRAPHICS RUNNING WINDOWS 7 MOTHER BOARD IS A PEGATRON M2N78-LA QUAD OK PROBLEM IS COMPUTER TURNS ON I GET...
Did you test the power supply with a power supply tester? You may only have partial power or very low power. I would try a power supply from another pc, Then I would check the ram in another pc if possible one stick at a time or if no other machine :
I would try removing all the ram and try one stick at a time in a different slot each time till it boots and then try a different stick the same way. You could have a bad memory stick and or slot.
I think its the power supply first, a bad stick of ram second or a bad ram slot third and the motherboard last. I would try all my parts in another pc first before a buy another motherboard
May 09, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Fans work green light shows on motherboard but cpu wont power up
Any HDD light on / if not could be failed HDD OR faulty IDE / Sata cable.
Did you get posting beep if not remove / replace ram / reboot.
If you did then either mobo / CPU may be faulty.
May 10, 2010 | Intel D845GVSR Motherboard
Unable to start - do not get post.
First of all that is too old system that you are using, problems can be your CPU's golden legs are not connected well on motherboard, second your ram memory is not working good, maybe is slower or faster than that motherboard can receive.
First of all disconnect everything from motherboard ...if it does not work :
1. Remove cooler from cpu
2. remove cpu from socket, turn around CPU and look at those golden legs if they are moved aside
3. if they are moved turn them back on the line use needle or small pocket knife to do it and do it carefully
4. carefully place CPU back in socket
5. put CPU protective grease
6. put back cooler on CPU
7. remove ram memory from slots
8. look at the golden legs if there is no broken use clean cotton swabs and pure medical alchohol and clean the ram golden legs put the ram back in slot
9, do the same with your graphics card if you are using AGP slot
10. put back power cable 20 pins and 4 pins
11. Connect keyboard and monitor cable
12. Use screwdriver to shorten the power on pins
If it does not work than you should say goodbye to that motherboard and old technology that you are using and buy motherboard socket 775 or socket AM2 and new cpu and ram its cheap this days to have real dual core computer.
Jul 11, 2017 | Albatron PX845PEV PRO 800Mhz Motherboard
Motherboard not starting Bios but fans start
Yes, had exactly the same problem earlier this week, the bios chip may be faulty, as you know all other components work, so it's down to the motherboard and a replacement is required
Mar 22, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Gigabyte GA-EP45-UD3P - Motherboard - ATX - iP45 - LGA775 Socket - UDMA133, Serial ATA-300  Logo
141 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
