Question about Motorola Mobility RAZR V3
Razr V3 - Outbound Calls fail
Bought a new battery when outbound calls always failed. Have two other Razr V3 in the family and others work fine from same place in the house, so it is not tower problem. New battery did not solve problem. Have switched batteries with other working Razrs but this phone regardless of battery always fails.
  • Darlene1943 Feb 21, 2008
    Will try it out. Actually have tried different SIM cards in this phone with the same failure rate. Will talk to T-Mobile. Thanks again.
  • Anonymous Apr 03, 2008
    cleaned battery
  • 47 Answers
Sounds like a signal problem check the bars of signal on your phn might be the antena try placeing your sim into one of the other razers and see if call goes through and let your service provider know they can send all info to phn like a new activation might be a issue where you cant connect to a tower if thats the case youll need to talk to your service providers tech department and have them check for the lrn easy way to see call your phn and see if you get dead air or fast busy signal
Posted on Feb 21, 2008
I am configuring a pri ckt in mitel sx200icp i cannot make outbound calls i have programmed pri card as per carrier in form 42 with NI2 - NI2bell have tried all procol variant incoming is fine
It sounds like the outbound Caller ID is not set up properly in form 22. You will need to insert *6 into the dial string. If this isn't set up, many carriers will reject the call as it doesn't see the correct outbound caller ID.
Sincerely,
Mark
Mar 16, 2011 | Mitel PRI Card T1 E1 (9109615001)
Canon imagerunner 2270 copier - I am trying to use the this machine to scan docs to an a yahoomail email account (it was working great all day long until now)...everything seems to be working as it normal...
You don't specifically say, but I'm going to assume that the machine was scanning to this email and then it stopped.
First, does the network operation outside of scanning to email work? If you can still print to the device or access it via the web interface your machine is still on the network. Power off the machine (for your Canon device this is on the back right corner of the machine). Maybe a reboot will fix it. If not remember that powering the machine off does not power down all of the circuit boards. Try the "Japanese reboot" and unplug the machine from the wall.
Do destinations not directed to yahoo.com work? If other destinations still work, then the copier did not change, the destination requirements changed. Maybe your spam filter has decided the copier is not an approved recipient.
If this still does not get you scanner love...
The bad news is that the copier does not care if the email address you are sending to is bad. The copier throws the email to heaven (your outbound SMTP server) and its done. You will get no failure on the machine, you will just not get the mail on the other end. If your machine gives you a failure to send message its because you failed to make your outbound mail server happy.
Whatever mail server you were using almost always uses an outbound user name password combination to permit outbound email to leave the machine. Did the user account associated with the outbound SMTP server change or get disabled?
Is the outbound SMTP passing through the yahoo.com, hotmail.com, gmail.com, etc mail server? If your answer is yes, check with those providers to see what their new outbound SMTP requirements are. There is less than a 0.1% chance the copier changed its settings and caused a failure. Yahoo changed.
If you were scanning out via a yahoo freemail account you have just discovered why in my years of setting up scan to email on several manufacturers lines of copiers I learned not set up scan to email using yahoo, hotmail, gmail etc as the outbound mail server. Inevitably one day these providers will change the setup required to scan to email. Or they will change their spam filters. They may not tell you when they plan to change it. They may not admit they changed it. The support person you contact may not know that it changed. They will not support you after they change it. They changed it specifically to reduce the undesired use of their mail servers (i.e. spam). When you call and ask them what the new settings are as often as not they ask if you can send and receive email from your web browser. If the answer is yes, they don't care if your email client works. They don't care if your copier scans to email. All they guarantee in their terms of service is that you can send and receive email form their web based mail interface.
I'm sorry if this sounds harsh, but after 10 years of fighting the man I no longer attempt to set up scan to email sending out through a third party or web based mail server. I tried many times to accommodate customers with free mail based email. Only to reach the day when that free provider would change the outbound SMTP settings and I would get a hundred calls from customers who told me my machine was broke because scan to email no longer worked.
Aug 06, 2010 | Canon imageRUNNER 2270 Copier
Can make outbound call on Blackberry Bold. Bought 2nd hand unlocked unit from the US. Can receive calls but everytime I try to make outbound calls it says: "Call failed due to SIM Toolkit control error....
This error is due to having an old SIM card.
Please talk to your carrier to get the latest SIM card.
You most likely have received an old SIM card batch.
Hope it helped.
Nov 23, 2009 | RIM BlackBerry Bold Smartphone
Can Not Make Outbound Calls
you need to check the phone settings to se if you have the call barring feature set, if it is then remove it
Nov 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Outbound calling problem
master reset the phone or check your call barring feature and deactivate it.
Motorola v3
I had this issue about a month ago. You need a new sim card. Drop by the nearest store and they should get you one for free since yours is bad. Otherwise standard is 15 bucks.
Feb 24, 2008 | Motorola Mobility RAZR V3
Auto bluetooth problems with Motorola RAZR V3 cell
don't think so.
maybe while pairing up the new phone you have turned down the volume on the earpiece?
Nov 28, 2007 | Motorola Mobility RAZR V3
Dialed Calls
hi
try ressetting it to factory settings...
Oct 12, 2007 | Motorola Mobility RAZR V3
Problem with Calls
if the phone is still under warranty go get a new one otherwise it sounds like a serious hardware problem!!!!
Feb 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
187 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
