Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
My audio card is not working on rear jack stereo.If i select 6 channel it still not working only on the others 2 jacks but the sound it's not stereo on that ones too. Stereo sound i have only on my front panel jack(headphones). Please tell me where is the problem and how can i fix it.
  • catalindizzy Feb 07, 2010
    Nevermind...the problem is hardware not software so...i need to change the motherboard on waranty.
  • 86 Answers
Try this site http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Feb 13, 2010
What can be connected to te audio output jacks on the back of this set?
You didn't include make and model TV; so only generalized answers are possible.
Typical RCA phono jacks like those shown in the blue box of the stereo amplifier below:
25998201-ac5bgneb45fvu53muoueauti-3-0.jpg will accept cables to connect to other audio devices. The audio RCA jacks are color coded RED (right) and WHITE (left) for low level stereo signals. Some have YELLOW jacks for Standard Definition video, ORANGE jacks for AC3 Digital audio and newer amps have HDMI jacks.
Connect the TV's audio OUTPUT jacks and a stereo pair of unused audio INPUT jacks on the amplifier with cables that have ends that match each. Turn on the stereo & TV and select the input on the amplifier that matches the stereo pair of inputs you used to connect to the TV. Adjust the volume to hear the audio over your stereo system's speakers.
Use the HDMI or AC3 sources for superior audio - including 5.1 (or better) Dobly Digital when possible. Otherwise, a standard 2 channel stereo program will be heard.
I hope this helps & good luck!
Dec 08, 2015 | Televison & Video
How d0 i get audio speakers to workj
Assuming the speakers are working, you can test them by plugging them into any other headphone jack, for example your cell phone. Check drivers & etc on computer make sure sound card installed correct. Also verify you are using the correct jack, there may be several for example microphone line in if you have a 5.1 stereo card they may also be ports for the rear speakers.
Dec 15, 2014 | Systemax Ascent Computers & Internet
The cd audio lead won't fit into the socket on the card
CD audio cables are usually restricted to 2 or 3 types (there may be others - I just haven't seen it yet). They look like these:
The one on the left is the type most often found on the CD drive itself and motherboard header pins; while the one on the right is the style most often used to connect to the jack on expansion cards like yours. Many sound cards offer more than just one way of interfacing CD audio. Sabrent is not an exception. Depending on the particualr model sound card, you may find that it has two different jacks like those shown below:
Either jack will support audio input. If your cable is unable to use either jack, you'll need to obtain a cable that will connect from the CD drive to the sound card. Bring the old cable and the card with you so that you can select the proper cable.
You can of course buy a "universal" cable. it looks like this:
This cable should provide a way to connect just about every type CD audio connector to audio input jack on a motherboard or expansion card. It is available for as little as $1.49 here.
I hope this helps and good luck! Please rate my reply. Thanks.
May 03, 2011 | Sabrent 6-Channel 5.1 3D Surround Sound...
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
How to hook up stereo speakers to your computer? on back of the stereo has a blue and red wires on the back.
You not only need the speaker but the amplifier [the main body of the stereo...where your Volume is] First make sure you have an input option at the back of the stereo,if your connector is different [e.g. you have stereo jack for the CPU and your stereo takes in RC only] http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html you don't have to worry about that,,,connectors are available. Attach the wire from the CPU to the Stereo,on the stereo select the input option from the front [it would be aux or any other option that corresponds to any external player attached] Play on. Let me know if any other queries...
Sep 06, 2009 | Computers & Internet
Problem with stereo output on Edirol FA-66
Possibly, your adapter of small to big is not a stereo adapter. Seems like a mono adapter.
Jun 15, 2009 | Edirol FA-66 Sound Card
SEQ-711 connection to sony STR D350Z
You can use the VCR audio connections for a stereo analog processor
Many people want to use an EQ with their modern multi-channel Digital Sound Processing gear but at best an analog 2-channel EQ (or any other processor) will only work with analog stereo sources. On most receivers, simply selecting the Tape Monitor disables all digital inputs. However, most DSP can still be employed with analog source material and a 2-channel processor with varying degrees of aesthetic pleasantness. Beauty is indeed in the ear of the beholder.
If that works for you, go for it. I do it, but I fully understand the limitations.
Mar 15, 2009 | Sony SEQ-711 Home Equalizer
Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
Nov 12, 2008 | Kenwood VR-406 Receiver
Speaker hook up
Shari,
It is my hope that I can help. This applies to the type of sound card on your PC.
- If you have a 2-channel sound card: Select 2 on the source selector switch on the subwoofer. Connect the green plug from the audio input cable to tyhe front jack on your PC sound card. With this input setting, your speakers will upmix the 4-channel signal and create a center signal for your speakers.
- If you have a 4-channel sound card: Select '4' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
- If you have a '6'-channel sound card: Select '5-1' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
Your sound card is located on the back of your PC Tower.
Good luck
Jun 24, 2008 | Logitech Z-5300 Computer Speakers
How do i hook up Altec Lansing AVS500 speakers to my computer
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 20, 2008 | Computers & Internet
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
