Machine drum will not turn at all, fills with water and emptys. No stange noises though
  • Archie Amphlett May 11, 2010
    Can you turn by hand. if so then could be motor brushes sticking or worn out.
    Sergeant:
  • 215 Answers
What make machine do you have as many are similar fault but differ in soloution
Posted on Feb 10, 2010
When i close lid it just makes humming noise and wont start
If washer hums but doesn't fill, water isn't getting to washer check screens where fill hoses connect to washer. Screens may be blocked. If washer fills then hums check to make sure belt is on. Tip machine up to view belt underneath.
Sep 26, 2013 | Maytag Ensignia MAV2757AWW Top Load Washer
Bosch classicxx
could be the engine check if the motor in not dirty the coper motor next to the brushes has got gold ish colour if not just clean with sand paper
the noise could be the bering ( if the noise is cracking ) ( if the noise is metal could be somthing in iner drum )
Jan 17, 2013 | Bosch Classixx WFL 2066 Front Load Washer
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks for contacting fixya.com
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
Sep 14, 2008 | Hotpoint WMA64 Front Load Washer
Washing machine repair
Hiya .. It is probably the bearings on the drum at fault, may have collapsed... is the drum making a noise when you turn it by hand?
Regards Faggly
Mar 23, 2008 | Washing Machines
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
