Question about Pioneer VSX-D511 Receiver
Display message "DSP NG"
I have a Pioneer VSX D512, infact was given to me. I have connected all the speakers and dvd to it but nothing is playing even the tuner.
It is diplaying "DSP NG" afetr any selection I am making but no sound is coming to the loudspeakers. I hear all relays clicking when I select the surround sound
Grateful if you can explain what is going on in my case
Thanks and regards
Jean
    Genius:
  • 1,665 Answers
Hi pay attention to do all interconnections right
You can get help dowlowding a low cost service manual at link below:
http://www.smpcshop.com/VSX-D414-VSX-D512-p-5216.html
Have a nice day and Good luck
Posted on Feb 21, 2008
  • Pioneer Master
  • 13,433 Answers
"DSP NG" The built-in microcomputer is not functioning correctly.
All you can do since you got it for free, you can try banging it with your arm a few times turn of the power, unplug 10mins put it back in. If the same message still keeps coming up after a few times and a few bangs. Then you should take it for repairs / contact your dealer.
Heh, what a tech I am, :D telling a "customer" to hit hes product.
Well good luck.
  • Ekse Feb 21, 2008
    Dont pay for a manual! in most cases you can find a free copy with google!
Displaying....DSP NG can some one please help? some kind of error.
In my experience, NG on a system made in Japan means "No Good" (error). NG might stand for something else, but regardless, it sounds like an internal issue with the amp.
Sep 24, 2015 | Pioneer VSX-D510 Receiver
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Mar 31, 2012 | Pioneer Audio Players & Recorders
Amp plays sound through previews of the movie - but NOT when the movie starts??
This sounds like a problem with the DSP chip. Turn off any DSP and surround modes in the unit and see if it at least plays in stereo. You may need to unhook the DVD player from the 5.1 inputs and put the front left/right into a CD or TAPE input to fully test this theory.
If that doesn't work, I have a VSX-D309 that just came up for sale (sorry, no remote)
Feb 22, 2011 | Pioneer VSX-D557
I have a Pioneer VSX-D411 and there is dsp ng flashing, what is it
http://www.retrevo.com/support/Pioneer-VSX-D411-Receivers-manual/id/385ci976/t/2/
I believe it's trying to tell you something is wrong with its digital sound processing.
This was the best source I could find on it:
http://www.avforums.com/forums/av-amplifiers-receivers/381823-problem-pio-vsx811s-no-sound-display-says-dsp-ng.html
If you switch it to satereo / direct and the light goes out I'd say that would clinch it.
Jan 15, 2011 | Pioneer VSX-D411 Receiver
No audio output
THE FIX - to audio problems that persist with the VSX-29TX and others using the AWX7272 DSP board is to replace the ROM on the DSP. My unit started failing on and off after 10 years of use! The intermittent DSP board is an Extremely Common and irritating Problem for this model! The replacement IC,(2) resistors + shipping and handling totaled $49.65 and my unit is finally fixed correctly! Don't believe other posts that you can get away with re-soldering; it will continue to fail again and again! Details of fix are:
Replacement for the old Pioneer ROM located at location IC 9374, should be done with the part PD6381A from Pioneer Electronics. You will also need to move (relocate) the 2 resistors (0 Ohm resistors) located at R9372 and R9371 to locations R9374 and R9373.
This component update applies to DSP boards marked as AWX7433, AWX7272.
This fix is validated (from Pioneer) on the VSX-26TX,VSX-27TX,& VSX-29TX it might also work in the VSX-908, VSX-908RDS and others as long as the same DSP board was used.
Let me caution and stress that surface mount soldering skills ARE REQUIRED to do this update! It also doesn't hurt to have excellent vision and/or an eye loop or microscope to check your work. Original ROM's were subject to timing changes internal to the part as a result of HEAT. This model does get HOT! The program was also modified as a further safeguard to re-occurrence.
Jan 30, 2010 | Pioneer VSX-29TX Receiver
What is dsp ng appear in the monitor
I'll ask again... What brand/model of monitor?
Does it seem like a receiver-to-monitor On Screen Display message or is it something the monitor is warning about?
How are the the receiver and monitor connected?
No more sound from where? The TV. The speakers running off the receiver?
What source(s)?
Give us some clues, please.
Jan 23, 2010 | Pioneer VSX-D711 Receiver
Pioneer VSX 818V No Sound
First thing to check is the Speaker Select Switch. It will say, "A" "AB" or "Both" it will be displayed on the LCD screen as well. Second if that's ok, Check the "Direct" switch. If it's on, turn it off. Generally if it's on, you will see a blue light if it's on (most receiver's)
If you still have No audio, hook up your DVD to the "Direct" input and turn "Direct" on. If you have audio then. The DSP chip is probably bad and you should take it to a shop and have them bench it first to confirm. Hope this helps
Dec 04, 2009 | Pioneer VSX-818V-K Receiver
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
Pioneer VSX-D511 Receiver Logo
1,386 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
