Question about Zanussi Washing Machines
The drum on the washing machine will not rotate even when i try to do it manually and the belt is broken
  • Zanussi Master
  • 3,463 Answers
Sounds like the main bearings have seized, or there is something fast between the inner and outer drum, and this is what has caused the belt to snap.
Try reall hard to push drum round in either direction, if it is something caught, you may free it this way enough to dermiune if it is bearing failure or not.
Posted on Feb 06, 2010
My bosch nexxt500 wont rotate the drum, the water pump work but the motor doesnt rotate the drum
Check if the lid isnt working as this prevents a roration . Else must be a loosened or broken belt that rotates the drum as the motor works . Hope this helps
May 30, 2018 | Bosch Washing Machines
Drum does not rotate
Is it making noises, Humming Buzzing etc.?
You should hope it's just the Belt NOT The motor / pump assembly.
If the belt is broken you should be able to rotate the agitator manually, if not it could be the motor.
Mar 03, 2015 | Washing Machines
Bosch Classixx 1400 Express - Drum not rotating.
Sounds like teh belt has either broken and come of of drum, or is simply lose. take the back off mchine; if broken buy a new one; if lose loosen motor bolts, press teh motor down until belt is taught and retighten. Check first to see if their is soap on the belt/pully/drum/motor carrying the belt as this could be causing it to slip
Dec 04, 2011 | Washing Machines
My whirlpool duet (Model # WFW8400TW02 )washer stopped working. the steel drum is not rotating and clothes are not getting washed. please let me know what could be the problem.. --Ritu
If this has a belt, then the belt may be broken or stretched out. Bad drum bearings can seize up and won't let the drum rotate anymore. A bad door switch can cause the machine not to run.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Start the power switch on and problem and drum is not running
Hi, the washer drum is not spinning, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 22, 2010 | LG WM-2277HW Front Load Washer
My washer's drum is not moving at all.
a worn out or broken drive belt perhaps?
Check your appliances parts diagram to see what it uses
to connect the motor to the drum.
I didnt find your model online so look here and see if you recognize one of these units.
http://laundry.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_washer_product_list.html
Mar 15, 2010 | GE Washing Machines
Drum does not agitate water goes in and it just humms, no agitation or spin
The drive belt is broken or the motor's rotor is stuck. Open the door and rotate the drum manually. The drive belt is worn or broken if you can freely rotate the drum. The rotor is most probably stuck if you cannot turn the drum.
Visual check can be done by removing the back panel. Remove the screws holding it to the cabinet and pull it off. Replace the belt if it is worn or broken. Simply wrap it around the drive motor pulley and on one side of the drum pulley. Rotate the drum pulley in such a way that the belt completely wraps around it.
Try to free the rotor if it's stuck by lubricating it and forcibly turning it back and forth until it turns freely. To remove the motor, disconnect the motor wiring harness and ground wire from the terminals and remove the mounting bolt. Pull the motor out of the mounting slots. To reinstall or replace, simply slide it back into the mounting slots and secure it with the mounting bolt.
In some cases, the drum will not spin due to a broken drum pulley. Post it back if that is the case.
Feb 07, 2010 | Kenmore 42822 Front Load Washer
I have a Tricity Bendix AW1000W. The drum will not rotate. The belt is fine, the brushes on the motor seem ok, the machine fills with water ok and the pump drains it ok but there is no drum wash rotation...
Could be anything , from a loose connection or broken wire to a control board or timer fault..You say the brushes are o/k, but if they are less than 3 or 4mm long, they need replacing.
Even the motor itself could be faulty.
I assume the drive belt is o/k, and correctly tensioned..
It is difficult to advise you further because thier are too many variables involved.
Please leave your comments on my suggested solution.
Thankyou.
Nov 25, 2009 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
