Hi I have a Philips 32inch ambilight TV about
Hi I have a Philips 32inch ambilight TV about 2-3 years old.I have found out that the hdi lead does not allow sound to the TV, just the picture.
Witha scart I get picture and sound.
Could it be the PLUG between the hdi lead and the tv. if so should I buy a new one?
Please help.
  • 12,061 Answers
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Posted on Feb 06, 2010
Testimonial: "Excellent help. I was not told this when I purchased the TV."
Philips 32 Ambilight PF 9986 TV Picture Problems - Fuzzy & Loss of Picture
What are you using for signal to the set? (Box?) and how are you connected? (HDMI?)
If HDMI try going Component
It may be the box/HDMI hook up causing the problem.
Mar 15, 2012 | Televison & Video
Ambilight isn't working when I press ambilight on the remote control. TV is about 5 years old
Have you tried turning it on in the menu options. Navagate thru the menu there is a setting for on or off on the Ambilights.
Jun 08, 2011 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Can i get my 32inch ambilight screen fixed ,it has a crack on it .
Hi Raverbaby768,
I am Sorry that you LCD 32inch screen cracked.
and I Fear the costlies part of LCD TV's is the Screen.
Yes, the screen is the most expensive part of your entire TV. The cost of repair + transportation will likely equal to or exceed the cost of a new TV.
I would suggest you to try fixing the screen in the near service centre.
If my Solution is informative, kindly vote.
Regards
BEADHZ
Apr 09, 2010 | Astar LTV-32ASB 32 in. LCD Television
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Jul 30, 2009 | Philips 42PF9631D 42 in. Plasma Television
Phillips ambilight 50 in red light problem
I had this problem on a 42" Philips Ambilight. After reading in another forum, opened up the back, and found 2 leaking capacitors on the center circuit board (main power supply pc board) toward the bottom. Tops of the capacitors were bludged out (10v 3300uF) and leaking electrolytes. Unsoldered the old ones myself, went to Radio Shack. They were out, so order 12 on ebay for $6.63 including shipping. Resoldered and works fine. Can't do it yourself? Take the board out (just unhook the cables & unscrew it ), and take it to a computer shop or tv repair or someone who knows how to solder, and have them change them. Piece of cake!
Jul 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV is a...
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Tyler
Apr 16, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My flatscreen tv gets green dots that appear on screen while...
The first mistake was the Philips TV. They are the worst tv. They are constantally needed to be updated. If you have warranty, I would recommend you taking it back or calling philips customer service and getting your tv repaired or replaced.
Apr 07, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Philips 7 year old 32inch cuts off while a high pitched buzzing sound stays until the tv is switched off at the mains
IF PICTURE PULLS ON RIGHT ADJUST BRIGHTNESS AND AND TINT UNTIL SCREEN SHOW FULLY AROUND PICTURE
Apr 04, 2009 | Philips 32PT5441/37 32" TV
Philips ambilight 42inch plasma
You can fix this yourself with a software upgrade - get the upgrade from Philips website - go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software". Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips lcd ambilight tv 32inch pf9531
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Apr 21, 2008 | Televison & Video
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
