Question about TallyGenicom 8008 Laser Printer
Error code I get the error "Replace Parts101" on the display. This isn't in the user guide. What's the problem? Our IT guy is dragging his feet.
Reset transfer roll
Posted on Oct 07, 2008
    Novelist:
  • 169 Answers
I beleve this indicates the printer has reached its 120,000 page service interval and requires paper feed rollers, seperation pads, transfer roller and cleaning roller.
These service parts and are not user replacements
Posted on Mar 31, 2008
Biahub photo copier malfunction detected C-D001 you are not give me a suitable answar
On this site: http://www.copytechnet.com/forums/konica-minolta/55127-bizhub-500-error-c-d001.html
This is what this one guy said, "this error code is a hard initialization abnormality, turn machine off and on,, if the code is still there re-initialize the hhd. If the code is still there, you probally have a bad hdd (replace)."
Here is a site that lets you download manuals: http://www.biz.konicaminolta.com/download/users-guide/
I hope this helps you out!
Feb 12, 2017 | Office Equipment & Supplies
What is err 70?
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested. Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
Hope this helps.
Aug 04, 2011 | Kenmore HE2 Plus Front Load Washer
Error code: dL F? What this code telling me?
Compartments that make device functions has encountered an error. The display settings provide indications of condition as guide to functionality. Especially when least tasked to produce results least within functionality displays an error code message. Restablished the features functions to capture user experiences. Also refer to the device user guide to ascertain details that manufacturer makes available either as functionality diagnostics or contact details to experts.
Feb 25, 2011 | Whirlpool Washing Machines
Error code f70
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
Oct 04, 2010 | Whirlpool Duet WFW9550 Washer
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
TallyGenicom 8008 Laser Printer Logo
101 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
