Question about Denon AVR-2805 Receiver
Denon AVR-2807 HDMI out signal
My Denon AVR-2807 surround sound receiver just presented a problem with what appears to be the HDMI output to my plasma TV. Has been working fine for over 2 years ... all of a sudden picture on TV looks to lack all black color ... only yellows, green and magenta. I can hook HDMI output from my DVD or cable box direct to the TV and it is fine. All set-ups appear to be the same as when it was funtioning properly. Could this be a failure of some kind with the HDMI out or something else?
I seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Posted on May 27, 2010
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
No sound from Russound ss-4 after connecting to BACK surround speaker connections on the 2807.
Check the speaker setup configuration in the setup menu. Many times the surround back speaker terminals can be assigned to something else like zone 2. They may just be turned off.
Dec 27, 2012 | Denon AVR-2807 Receiver
Pc connection to denonAVR 2807 receiver
ideally you would use an HDMI video cable but few video cards support that standard yet.
Your next best choice is to use a DVI to HDMI connection cable. They work very well as the video signal is the same between the two the only difference is that a DVI cable does not support sound so you will have to use a 3.5mm stereo (male) to RCA cable for sound.
Now there could be complications there as your receiver may not be able to display a video images off the hdmi cable while combining sound from the analog cable.
Some computer video cards have an RCA or s-video output and that will work BUT the picture quality is going to be bad, real bad.
a better option is to find a device that allows you to connect to your network to view images and videos. There are a number of such devices such as x-box 360, Tivo series 3 etc..
Hope that heps point you in the right direction
Jan 10, 2010 | Denon AVR-2807 Receiver
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
Can't get the sound to work on my TV using the Denon AVR-2807
In the 2807 the HDMI out is a video out only. Audio is not processed through the HDMI output.
If you are using speakers it is best to adjust the playback modes to stereo if you are annoyed with surround sound modes.
Please comment if I helped.
Oct 04, 2009 | Denon AVR-2807 Receiver
I have a denon avr-2807 receiver. on tv mode, i can only get analog signals. i am using an optical cable and the signal is only transmitted in digital. how can i correct this?
An optical cable is digital but its only audio not video. Are you connected to a cable or satellite box, are you using composit video, s-vid, component video, or hdmi? What kind of cable goes from your denon to your tv?
Aug 19, 2009 | Denon AVR-2807 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Itunes assigned to CD stereo outputs to zone 1 but not zone 2
Ron Digital audio will only reproduce in the surround area you will have to connect using analog connections in order to get that sound in the 2nd zone
Dec 14, 2008 | Denon AVR-2807 Receiver
Condition on HDMI input when Denon AVR-2807 switched off
hello if you know this spitter conduct voltage and its feed from main device and when you connect another it send it ground you have to do this chech with a voltmeter in the hdmi splitter output is not dc present if so change it cause is not blocking dc current saludos
Dec 04, 2008 | Denon AVR-2807 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
Denon AVR-2805 Receiver Logo
920 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
