Question about Sanyo DP19648 19 in. LCD TV
I hooked up my Dvdto my tv .When you put a movie on the picture is Red But when you put it back to like chanell 2 you have colore
Either you have a disconnected or bad component cable. Replace and the picture should be fine.
Posted on Mar 18, 2010
Testimonial: "thank you I bought a new cable and it worked thank's again."
How do I hook up DVD player
Liz,, most DVD players come with RED, Yellow, White cables. on back of ur DVD player find the holes with the matching colors. and insert cables, now go to ur TV , on the back you should see some of the same colors plugins ,.once u have done that . put in a DVD and hit play. now go to the input/source button on ur TV or remote and push it . u might see a drop down menu if u do highlight the AV or Video 1 or 2 or 3 till u get a picture. when finished u will have to hit the input button and go Back to where u were in order to watch what u had it on before. NOW if u have a Blu Ray DVD player all u need is the HDMI cable , find the HDMI output onback of player and on the TV find the same. your tv might have 3 or so HDMI inputs ,, any will work. as before put in a movie, use ur remote , input button and find the HDMI on the menu and high light it. .
Jan 25, 2015 | Televison & Video
Dvd plays in black only
Be sure dvd player is correctly connected. If you connect the yellow video composite out the dvdto the input on the tv that is not yellow you are probably trying to watch it thru the component in . The component in is 3 wires green blue and red. if all three are not connected the picture will have no color. If you have 3 wire connection on dvd connect it to 3 wire in on tv the other red and white are audio.
Mar 15, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
I'm having problems hooking up the dvd player. Where do I connect the wires in the back of the tv
The most common way to connect a DVD player to a TV is to use composite cables which are yellow, red, and white. The yellow cable carries the picture while the red and white cables carry the audio. All you have to do is match the colors to the correct holes in the back and then put your TV on the correct input or source when you're ready to view a DVD movie.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Aug 05, 2009 | Televison & Video
Don't have manuel and don't know how to Set up Hitachi VCR
Such a simple job. First check if the cables are connecred properly
1. Audio OUT from VCR to AUDIO IN of TV.
2. Video OUT from VCR to VIDEO IN of TV
Then switch the TV ON. Select 'Video' on the TV/Video
selection button on the TV's remote control.
Your TV screen will show a display like 'Video' or 'AV'
Play a cassette and you should be able to see the picture...
Happy Viewing.
Apr 01, 2009 | Televison & Video
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
PSP 6 pin gen 2 cable not working on tv?
you have the wrong cable. the cable you have is for HDTV's only.
by the ports on the TV, you have a standard TV.
The cable's colors are Red, Blue, Green, Red, and White. If you have a HDTV or these ports on the back of the TV, connect them like in the picture.
from what you said, it seems like your TV's port colors are Yellow, Red and White. If you only have these ports on the back (Yellow, red, white), you need this cable:
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Sanyo DP19648 19 in. LCD TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
