Question about Nokia 6300 Cellular Phone
Low voice recording,heatingup of battery,
Sir, When i try to to record the speech ,the quality/ volume of recording is very low.Also down loaded indian classical music suffer with the same problem.
2) 75% of the battery get exhorted within 2 hours of mp3 use.Also it get heated up
    Problem Solver:
  • 14 Answers
I think there is a recent update by nokia for 6300 for solving this battery problem, you can contact the nokia service center. Its usual for all mobiles that the phone gets heat ups.
Posted on May 23, 2008
    President:
  • 1,017 Answers
That's about right, the batteries take quite a pounding when you stay online for a long time. Your battery might be on it's way out, that's why it gets hot under pressure, If you replace the battery buy only the real thing IE. a Nokia, anything else is false economy.
Posted on Feb 22, 2008
I have an lg tv model49uj7700. the vocal volume is very low while the background effects and music is very loud.how can i fix this
I suggest you try changing the sound modes to see if it improves the speech. Some TV have speech settings that will boost voices.
Oct 09, 2017 | LG Audio Players & Recorders
I have recorded wedding speeches on my Sanyo ICR-B150 Handheld Digital Voice Recorder but am no longer able to transfer the contents to my pc. I would also like to copy the speeches to disc or a memory...
Worst to worst you can simply transfer them via analogue out, rather than digital out. Just be careful of your output volume.
It wouldn't hurt to find out why digital out doesn't work any more.
Mar 16, 2014 | Sanyo ICR-B150 Handheld Digital Voice...
On the microphone setup page, it keeps on asking me to say 1, 2, 3, 4, 5, and I made sure my audio settings were correct in my control panel. i don't know why it's not working!
Check to make sure that you have connected the microphone to a microphone port. Headphone ports are identical to microphone ports physically, however they will not accept audio input. If you have verified that the microphone is connected to a microphone jack and the device still does not work, you may be using an old or low quality microphone which is not good enough to detect your voice. You might need to buy a higher quality microphone. If this is not the case, your microphone may be broken. You can check this by using a recording program like audacity (http://audacity.sourceforge.net/download/) to do a test recording and make sure that the microphone is actually recording. If none of the above seem to be the issue, then make sure you are speaking loudly and clearly. Voice recognition software is not always good at picking up your voice and you may need to enunciate your speech more, especially if English is not your first language or you have an accent. Good luck!
Jun 01, 2011 | Computers & Internet
Which button is which
On the top of the device are the recording indicator and built-in microphone. On the front of the device to the right of the screen: (from top to bottom) ERASE, MENU, VOLUME UP, VOLUME DOWN
The MENU button cycles through these options in this order: Folder, record condition, record quality, AVR on/off, play condition, beep tone, set year/day/12 or time, key lock on/off
On the right side of the device: (from top to bottom) RECORD, STOP, PLAY, FORWARD*, REVERSE* *(FORWARD/REVERSE can be used in the MENU mode to select options)
On the left side of the device: (from top to bottom) External microphone jack Connects headphones
Here is an online (*.PDF format) manual for the recorder: MANUAL
I hope this information helps! :-)
Mar 06, 2011 | RCA RP5020 Digital Voice Recorder
When im recording,the voice is to low
DEAR SIR,
R U USING LINE IN OR MIC , IF MIC , INCREASE MIC VOLUME FROM VOLUME CONTROL PANEL, & IF U R USING LINE IN INCREASE VOLUME OF LINE IN FROM CONTROL PANEL ..
Jan 05, 2011 | Computers & Internet
My recorder is locked and I can't locate the manual to unlock it! RCA RP5120-A
The manual says this about it;
Keys lock
To avoid accidental key activation, slide the key lock selector toward the lock icon to lock the keys.
Reverse the step to unlock them.
I have included the link to download your manual for free for your convenience
http://www.voxxsupport.com/images/manuals/RP5120/media/RP5120_UMEN.pdf
Please do take a moment to vote on the answer as to whether it helped.
Many thanks.
Jan 29, 2010 | RCA RP5010 Digital Voice Recorder
Logitech 9000 recording problem
My suggestion for recording music of any sort is to disable the cam mic and use a good quality mic plugged into the sound card as the mic in a cam is more suited to voice.
Aug 24, 2009 | Logitech QuickCam® Pro 9000 Personal Web...
Don't have speech recognition tab in control panel-speech
Go to control panel click on sounds audio dvices then tab on voice and click on test hardware then click on next now there are two options one is recorder and second is playback. Now click again on next when you click on next both volume should be enable then click on next and then finish. Now 100% guaranteed it will work and you can voice chat now. Cheers!
Aug 01, 2009 | Logitech 250 Headset
Headphones with mic model # na
Hello...
Try this one:
1.Click on Start
2.navigate to Control Panel
3.click on Sound, Speech and Audio Device
4.click on Sounds and Audio devices
another window will appear
click on the Voice tab
on the Voice Recording
click on Volume
there should appear another window
adjust the Mic Volume
hope this helps
Oct 09, 2008 | Computers & Internet
Nokia 6300 Cellular Phone Logo
59 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
