Question about Lexmark P6350 All-In-One InkJet Printer
Error 2200 I was using my Lexmark and an envelope got stuck. After struggling to get it out I now get the message error 2200 and no matter what button I press the printer turns off and after a few seconds it turns back on. After the blue lights stop I get the same message. Help
    President:
  • Lexmark Master
  • 2,017 Answers
Just unplug power cord and the usb cable and remove the cartridge and reinstall it again and make sure there is no paper stuck inside and the print head is moving just move it slowly to right and left and close the cover and plug the power and see .
One more thing when you removing the stuck envelop that time there is no part is come out only you removed the paper. If find any suspect part inside in the printer like physically damage or some thing . you can try this thing also
1.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Have a nice day and do not forget to rate please...!
Posted on Feb 06, 2010
Testimonial: "I've tried this and found that it now works as long as I don't have the unit fully closed, I now need to leave the unit slightly open for it to work. "
  • 136 Answers
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
IF THE ERROR MESSAGE DID NOT COME BACK....
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Testimonial: "OK thanks for that. It looks like I need a new printer"
I have Lexmark p4350 I can not copy, and show error 2200
According to the Lexmark site the 2200 error is a jam, possibly the scanner. Try unpluging the power at the printer, remove the paper, and see if there is any paper stuck in the unit. Another possibility is the cartridges are messed up. If you don't find paper stuck, remove the cartridges, and reinstall the color one. If the error goes away, the black cartridge is possibly bad. Another problem you can't fix, which is the scanner glass cracked. In that instance or if the cartridge swap doesn't work, contact Lexmark to fix the unit.
Sep 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
Halfway through sending a fax I got an 'error 2200 - conslut your user guide' nessage'. Is there a user guide online or can you help me?
The 2200 error message indicates that the scanner has stalled. Please refer to this article in the Lexmark website to determine and resolve the problem: 2200 Error on the Lexmark X7100 Series All-In-One.
May 03, 2011 | Lexmark X7170 All-In-One InkJet Printer
I get a 2200 message from my lexmark717 how can fix it?
The 2200 error message indicates that the scanner has stalled/jammed. This article in the Lexmark website will help fix the problem: 2200 Error on the Lexmark X7100 Series All-In-One
Apr 20, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I cannot get the envelope fuction to work correctly. The printer tells me I have a paper jam, when in fact I am trying to print an envelope
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
For further assistance, please call Lexmark Technical Support.
Mar 08, 2011 | Lexmark C532n Color Laser Printer
2200 error
The 2200 error message on the Lexmark P6250 All-In-One Ink Jet Printer indicates a scanner stall or jam. Please refer to this link - http://bit.ly/aAy3bU for the steps that will help you resolve the issue and clear the message. If the error is still the same I would strongly suggest that you contact Lexmark Technical Support.Thanks.
Aug 13, 2010 | Lexmark P6250 All-In-One InkJet Photo...
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error code 2200
You need to clean NVRAM on Lexmark X7170 printer. Please find below the steps to clear the NVRAM on the Lexmark X7170:
1. Press the 'Quality' button and the '9' button at the same time.
2. Press '1,2,3' in succession per the LCD.
Note: This will delete all user settings including the speed dial list.
Next try to make a coy on the printer itself and let us know the result.
Apr 16, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Carriage jam message HP D7360
Try opening the top cover again and look into the printer with the help of flashlight or some light. I think you will find that there is paper stuck on one side of the carriage. Do this aspa since if the pape is really there, t will not let the carriage sit over the rubber gasket and will dry the ink out.
303Electronics eBay Stores
http://www.303electronics.com/
Jun 01, 2017 | HP PhotoSmart C4280 Laser Printer
Lexmark p6210
I have an error 2200, how do I solve it? please help
Apr 06, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark P6350 All-In-One InkJet Printer Logo
161 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
